Go to Post The name of the game will be "Conjunction Junction". The robots will be tasked with hooking up words and phrases and clauses. You're welcome. - Travis Hoffman [more]
Unread 22-10-2016, 00:40
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
Re: pic: High Traction Drivetrain Concept
Originally Posted by cbale2000 View Post
On an 8wd robot where the center wheels are lower than the outer ones, the robot simply tilts back onto the rear wheels and maintains traction, but for a no-drop drive system, this effect will result in all of the robot weight being shifted on to you rear wheels, which in this case, have the lowest friction. All other things being equal, this design will likely not stand up in a pushing match with the majority of drop-center 8+ wheel robots, IMO.
It seems like this issue could be easily remedied by mounting your drive motors/gearboxes (and battery if you have room) to the front of the robot to make it less resistant to shifting onto the back wheels. You could also build a suspension system into the wheels so that when the frame tilts, all the wheels stay on the ground (some might say that this would be too heavy, but you can make suspension systems fairly light ).
It isn't shiny enough.
