Go to Post No one can improve your team's situation but your team. - Ryan Dognaux [more]
Unread 23-10-2016, 16:44
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is online now
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
Re: VexPro Clamping Gearbox Dead Axle
Originally Posted by Ari423 View Post
I think I'm just going to do it live axle. It doesn't need it, but it seems like a lot less trouble.
Much of the VexPro products are based on live-axle motion transfer. Using these products outside of their designed usages certainly isn't against the rules, but it can be more trouble than what it's worth. Figuring out when and how to modify COTS products to your purposes takes some planning and some experience. (Hey, that sounds suspiciously like engineering.)
Also, are you sure the clamping gearbox will hold securely enough to keep the tension in your chain? I know on drivetrains, people have noticed slippage when they used the clamping bearing blocks without the WCP cam. I don't know if you'll run into the same problem.
