Go to Post Thanks everyone for being so positive- this just reaffirms why I love F.I.R.S.T. and volunteer my time to this program and the awesome students involved! - Weightmn [more]
Unread 23-10-2016, 20:13
GoldenGollem's Avatar
GoldenGollem GoldenGollem is offline
Java Programmer
FRC #2509 (Hutchinson Tigerbots)
Rookie Year: 2015
GoldenGollem is an unknown quantity at this point
What Is The Minimum Needed?
My team has recently decided to attempt to buy a new laptop for the incoming season. We have been wondering what type of laptop to buy. We will be using this to program and to use the DS. My question is what are some of the teams requirements for a driverstation and programming laptop. We don't plan on spreading a ton of money but would definitely consider suggested laptops.
GoldenGollem -Hutchinson Tigerbots 2509
2015 - Mini-MN Regional 2nd Place Finalist
2016 - Mini-MN Regional 1st Place Finalist
Unread 23-10-2016, 20:15
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: What Is The Minimum Needed?
Correct me if I'm wrong, but I believe several teams used the Teammate laptop for 200 credits from FIRST Choice last year.
Unread 23-10-2016, 20:19
Jalerre's Avatar
Jalerre Jalerre is offline
FRC #4965 (FIRE)
Jalerre is on a distinguished road
Programming and the DS software does not require a very powerful computer. Pretty much any modern processor will do. You probably want a minimum of 4 gb of RAM. An SSD is nice for fast boot times. Also a built-in ethernet port is convenient but not absolutely necessary because you could use a dongle.
My personal recommendation is the Lenovo Thinkpad 11e. Its a small laptop with an ethernet port and its very durable for the occasional accidents.
Vex
2013: 415 - Fabrication, Programming, Electrical
2014: 415D - Captain, Programming Lead
FTC
2014: 7354 - Programming Lead
FRC
2013: 415 - Safety Animation, Fabrication
2014-2015: 4965 - Programming & Electrical
2016: 4965 - Captain, Programming Lead, Electrical
Unread 23-10-2016, 23:07
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
As has been noted, the minimum is pretty low. Going over that minimum will greatly reduce your compile & deploy times. While 3946 has only used java, I understand that c++ has the fastest compile/deploy times, with java not too far behind, and NI Labview being much longer. (I have not seen any comparative numbers on python.)
When selecting a computer, the one thing I can think of that has been a constant for at least 20 years (I clearly recall advising a 286 vice 386 buy decision this way ca. 1996) is to ensure that you have ENOUGH RAM. For a computer which typically has one or two applications running at a time (e.g. robot programmer with some help screens on a web browser) on windows, this is usually about 4x the "box spec minimum" RAM. If you run lots of apps and windows and tabs at the same time (like my home and work PCs), the numbers are 8x or 16x the box spec. On any given date, a "current" version of Linux will typically perform at least as well as a "current" windows box with about half the RAM of the windows box.
For programming and casual browsing (web help and occasional graphics and streaming non-HD video), the graphics capability is not an issue these days; even the smallest built-in chipset graphics do way more than you will need. If you plan to do HD video or CAD, you will probably want as much or more RAM in your video card(s) as on the PC proper.
Edit: And I concur that a Lenovo Thinkpad is a good platform - built as IT for the business road warrior, they are rather resistant to the rigors of FRC. There are several times I have suggested a used Thinkpad over a new "generic laptop", and a couple of times I've done that with my own money.
Unread 23-10-2016, 23:30
krtanjek's Avatar
krtanjek krtanjek is offline
AKA: Donnie Krtanjek
FRC #0225 (TechFire 225)
krtanjek has much to be proud ofkrtanjek has much to be proud ofkrtanjek has much to be proud ofkrtanjek has much to be proud ofkrtanjek has much to be proud ofkrtanjek has much to be proud ofkrtanjek has much to be proud ofkrtanjek has much to be proud of
One thing I will advise is that the laptop have a built in ethernet connection. A lot of new laptops do not have a built in ethernet connection and you will have to use a USB to ethernet dongle.
TechFire uses Lenovo T series Thinkpads for driver stations as well as scouting and CAD thanks to one of our sponsors.
The Lenovo laptops have held up very well for the last couple of years when we started using them.
Unread 23-10-2016, 23:54
ollien ollien is offline
FRC #5202
ollien has a spectacular aura aboutollien has a spectacular aura aboutollien has a spectacular aura about
I assume you're referring to the Classmate. These will serve basic needs, but I don't miss programming on these machines. It'll do if you're short on cash, but I can't recommend them.
