Go to Post Because FIRST wants everyone to have a sense of accomplishment even if you didn't accomplish anything during the match. - Koko Ed [more]
Go Back   Chief Delphi > Technical > CAD
Unread 24-10-2016, 06:57
CadmesFTC CadmesFTC is offline
CadmesFTC is an unknown quantity at this point
Matrix and Tetrix KOP models
As part of an internship assignment, we have been working on setting up a library of Matrix and Tetrix parts found in the KOP. Unfortunately we have not been able to make all of them, since some of the parts do not have a CAD model attached to them on the site, nor are their dimensions given. We also currently do not have a KOP available to measure these parts.
The parts we are missing are:
Tetrix:
39593 Standard-Scale Pivot Arm
39381 Standard-Scale Servo Front Mount Bracket
39280 Adjustable Servo Bracket
38009 Battery Clip
Matrix:
11-3204 4.5 mm M3 flat point set screws
08-0024 Thin 4-hole Wheel
11-3404 4mm M4 Flat Point Set Screw
11-4124 24mm M4 Button Head
16-0001 Dual Omni Wheel
17-0709 Triangle Plate 6-8-10
50-0011 Servo with Metal Gears
50-0070 96mm Wide Wheel Kit
14-0014 12V Battery
14-0004 Battery
If anyone happens to have these CAD models, or can even help us by measuring them, it would be greatly appreciated.
When we have finished the library we can make it available to everyone, so the sooner we can make these parts the better
