Go to Post Maybe you should whack it a few times with a hammer. That always seems to fix our robots. - Adam Y. [more]
Unread 10-24-2016, 05:31 PM
pilum40 pilum40 is offline
Steve Miller-Coach-Team 3355
AKA: Steve Miller
FRC #3355 (Bigg Redd)
pilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud of
[FTC]: Mini Linear Acutator Legal for FTC?
I've been working with some of my sophomores and we have come up with a ballcapping mechanism that uses a gripper claw with a small linear acutator in the center pushing the two claw fingers out and in. We used a Dart acutator in FRC but were not sure if using a linear acutator would be legal in FTC. Any pearls would be welcome.
Thanks
Steve Miller
FRC 3355/FTC 10576
Purple Vipers
Unread 10-24-2016, 07:15 PM
FIXIT3491 FIXIT3491 is offline
FTC #3491
FIXIT3491 is an unknown quantity at this point
Re: [FTC]: Mini Linear Acutator Legal for FTC?
Last year, we used an Actuonix (formerly Firgelli) servo motor on our robot. A few inspectors were interested, but only because they hadn't seen it before. It plugs directly into the MR Servo controller.
We asked in the game forum if it was allowed. Here's the answer.
"6v version with the RC control option to make sure it is compatible with the allowed servo controllers."
Here's the direct link on where to purchase them.
http://www.actuonix.com/RC-linear-servos-s/1853.htm
FTC 3491
FIX IT
Unread 10-24-2016, 07:40 PM
Billfred's Avatar
Billfred Billfred is online now
Thanks
Steve Miller
FRC 3355/FTC 10576
Purple Vipers
Your key things would be:
1) One degree of freedom (RM02)
2) Legal servo controller (RE08)
3) Legal motor (RE09) or servo (RE10)
What you're describing isn't common that I've seen (elevator-style lifts are more common), but I hope you pull it off!
