Go to Post No, I've never done 3D programming before, but I'm young and naive, so I still think I can do it. ;) - Ryan M. [more]
Unread 24-10-2016, 11:08
kingca kingca is offline
FRC #0108 (SigmaC@ts)
Rookie Year: 2015
kingca is an unknown quantity at this point
Problem with Joystick axis problem
Our team is using c++ and we been having a problem with the joystick axis. The problem occurs when we plug in the joystick into the USB port and it is not configured properly sometimes making the robot start moving by itself. Has any others teams had this problem and how have you solved the problem?
Unread 24-10-2016, 11:12
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is online now
Not Allowed Near Power Tools
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
nickbrickmaster is an unknown quantity at this point
Re: Problem with Joystick axis problem
It's a common problem, especially on video game consoles. The solution is to make sure that the joystick is at center when it is plugged in. The reason is that the joystick takes the value when plugged in to be the zero value.
If that doesn't work, introduce a small deadband in your code, 0.05 abouts.
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
Unread 24-10-2016, 11:13
jimbo493's Avatar
jimbo493 jimbo493 is offline
Quasi Mentor
AKA: Jimmy
FRC #3357 (The COMETS)
Team Role: Electrical
jimbo493 is on a distinguished road
Is it just moving a little bit, slowly? If so I would assume that you may want to put a dead zone around the center of the axis, since a lot of joysticks dont always fall back to dead center. I assume if you move the axis and let go it stops the movement?
FTC Student 2011-2012 FRC Student 2012-2016
FIRST Alum/Quasi-Mentor 2016-present
Unread 24-10-2016, 11:41
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
How many axes does your joystick have?
We have a 3-axis joystick where (at least in 2013 using Java, don't know if any software fix happened later) the x- and y-axis made perfect sense, but the "twist" axis was actually called "throttle" in the code, and "z" and "twist" were both the little paddle-like axis on the base of the stick.
So when we first went to run our mecanum (thankfully it was on blocks), we had no idea why it was running so fast and seemingly randomly, but it was because the little paddle wasn't at 0 (which is around 45 degrees), but all the way down at 1/-1.
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 24-10-2016, 19:07
orangelight's Avatar
orangelight orangelight is offline
AKA: Alex
FRC #0548 (Robostangs)
orangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to behold
I ran into this problem when debugging another teams code, I believe they were using a Logitech joystick. The problem was as nickbrickmaster said, the joystick was not centered. We just re-plugged in the joystick and it worked as usual.
