Go to Post "Recycle Rush? What's that, some sort of charity marathon?" - Chak [more]
  #31   Spotlight this post!
Unread 24-10-2016, 05:54
carpedav000's Avatar
carpedav000 carpedav000 is online now
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
Re: pic: High Traction Drivetrain Concept
Originally Posted by cbale2000 View Post
The weight solution is a good one for pushing matches, but it affects turning in most drives and only works in one direction (often I've found you need to be able to push from either side).
The suspension is also a good solution but far more complex to build.
I'm working on fixing the complexity part
It isn't shiny enough.
  #32   Spotlight this post!
Unread 25-10-2016, 13:22
S1LK0124's Avatar
S1LK0124 S1LK0124 is offline
FRC #0234 (Cyber Blue)
Rookie Year: 2016
S1LK0124 will become famous soon enough
I don't know if anybody else asked this but, what is the likelihood of it tearing up the carpet? I know that the drivetrain isn't like ours from this year in the sense that we used tank treads instead of a wheel-based drive, but our drivetrain had a lot of traction, and when combined with the high torque that we had, our treads tore up the carpet a few times, resulting in a few deactivations. We later combatted this by reducing the top speed of the robot so our deceleration wouldn't be as fast, and reducing the amount of torque. I don't know if you've already considered that, but I really like your design and I don't want it to run into trouble should you wind up using it!
  #33   Spotlight this post!
Unread 25-10-2016, 13:40
I don't think this would neccessarily be an issue for this drivetrain. It isn't using roughtop/grooved/patterned wheels and the contact area on the carpet is much less than a treaded drivetrain (especially treaded drivetrains that have layouts identical to or similar to yours).
  #34   Spotlight this post!
Unread 25-10-2016, 13:44
S1LK0124's Avatar
Rookie Year: 2016
Okay cool. I didn't think it would, but any question is worth asking. Especially with a train like this, it seems like a really well thought out idea, and I'd hate to see an unforeseen problem arise from this! Especially after this year, our team had a lot more unforeseen problems than in the past. We've solved these problems on the robot and in our building process, but it's still a really sad thing to see when you think you're gonna do good and something nobody expects shuts you down.
  #35   Spotlight this post!
Unread 25-10-2016, 14:16
Yeah I know the feeling
