Go to Post Yes, good job being calm and asking about the validity of a rumor before fanning the flames and assuming the conspiracy must be true. - Greg McKaskle [more]
Unread 26-10-2016, 09:33
bobbysq bobbysq is offline
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
pic: Testbench with PDB backpower
Unread 26-10-2016, 09:35
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
Re: pic: Testbench with PDB backpower
Why did you choose to back-power the PDP instead of just plugging the power source into the input like a normal battery? Weren't you afraid of the possibility of breaking the many expensive pieces of electronics by using them "off label"?
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 26-10-2016, 10:04
Rookie Year: 2015
Mostly because I didn't have connectors to hook up the power source to the PDP input terminals. I wasn't afraid of breaking it because previous experience has taught me that all of the 12v and ground rails were connected directly to each other. The only thing I was worried about breaking was the power supply. (which I may have done something to with the power surge from a CIM stopping)
But it worked well for the test!
Unread 26-10-2016, 17:05
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
They cannot all be connected directly to each other: each circuit has its own breaker and current meter. Running power backwards through the breaker would be of no consequence (as your power supply is probably not capable of enough current for long enough to trip a 40A breaker), but running current backwards through a current meter designed for polarized current certainly could.
I recommend verifying that you check on circuit you used as the "input", both to verify that it still works, and whether its current meter still functions properly before you build a robot with that PDP and have incredible fun troubleshooting the problem.
(Besides, you wouldn't have needed any more hardware than you have in the picture - just loosen the input 6AWG feeds into the PDP a bit, slide in your smaller supply wires underneath, and tighten.)
Unread 27-10-2016, 11:22
Rookie Year: 2015
Is there a way to check the current meter without having to put much in the code? I assume it'd be easy to display it in SmartDashboard or in the web config.
Also, maybe I should just make a straight-up test program since I highly suspect we've damaged a few current meters already due to an unrelated thing. From the manual:
Warning: Inductive loads (motor, compressor) must have a power management device(motor controller, PCM, spike) between itself and the PDP. No inductive loads (motor,compressor) may be directly connected to the PDP channels as this can damage current sense circuitry.
We have probably done this with a prototyping setup involving a dipole switch connected as an H-bridge to a motor. It might be safe though, if the issue is only referring to the reverse voltage that a motor generates when slowing down.
Unread 27-10-2016, 11:26
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
No code necessary. Go to the roboRIO web interface, pull up the PDB, and I think you click test. I'm going from memory here. You'll see the estimated current value for each circuit. Change the current going to that circuit and see what changes.
Unread 27-10-2016, 11:38
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Team Role: Student
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
You can also see it in the log viewer in the driver station: that's incredibly useful for debugging stalling as well.
F4 Network Website Designer
2010-2012: A Whole Buncha FLL Teams; Team Spirit, Gracious Professionalism Award winner
2015-Current: FRC 1982, Captain, Electrical Lead
Beginning FIRST Volunteer
Moderator on the FIRSTwiki
Unread 27-10-2016, 11:43
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
I thought about this problem too, but then I remembered that any type of back current from the robot moving also generates this current, so hopefully the PDB is designed to handle running current backwards.
The problem of course being that microcontroller reading the voltage drop across the shunt resistor will have negative voltage at it's inputs. However, I bet it goes through an amplifier before going to the microcontroller, and those often handle negative voltage just fine.
Back on topic though. We have a similar test board using a 12V, 30A power supply that is wired into the battery input. It's been working great for testing anything from robot code, working on vision processing, or just trying new things.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
