Go to Post I believe you have the right to develope your own opinion. I would suggest it be based on actual experience and facts. - Mike Copioli [more]
Old 10-28-2016, 01:42 PM
Bpk9p4's Avatar
Bpk9p4 Bpk9p4 is offline
FRC #1756
Bpk9p4 is on a distinguished road
Rivnut Tool
My team has been using rivnuts for the past couple years and we love them. I was wondering if any other teams use them and if so what tool do they use to put them in. We currently use a hand powered rivnut gun https://www.grainger.com/product/POP...AS01?$smthumb$
It works great but is hard on your hands after a while and prone to lots of error. Has anyone used an power tool rivnut gun?
2015 Midwest Regional Finalist
2015 Central Illinois Regional Winner
2015 Newton Division Finalist
2015 Newton Quality Award
Old 10-28-2016, 01:59 PM
topgun's Avatar
topgun topgun is offline
FRC #2846 (FireBears)
topgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant future
Re: Rivnut Tool
Think about what the rivnut is doing, and how you can make your own tool.
Drill a close fit clearance hole for the size you are using in a piece of thicker steel. Put a bolt through the hole, screw the rivnut on the other side so it's tight. Place the rivnut in the mounting hole where you want it and use a powered drill to turn the bolt. Tightening the bolt will pull the rivnut bending portion tight to the mounting hole.
-T
Old 10-28-2016, 02:05 PM
nirmatt_1690 nirmatt_1690 is offline
FRC #1690
nirmatt_1690 is an unknown quantity at this point
Re: Rivnut Tool
If we need to put more than just a few, we use a pneumatic gun.
Old 10-28-2016, 02:14 PM
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Rivnut Tool
We've always used a wrench-driven tool, McMaster PN 96349A380.
2016: Lake Superior WFFA
Old 10-28-2016, 02:30 PM
Bpk9p4's Avatar
FRC #1756
Re: Rivnut Tool
where did you get your pneumatic gun from and you have any idea on the cost. All the ones i can find are very expensive
Old 10-28-2016, 10:00 PM
Thayer McCollum's Avatar
Thayer McCollum Thayer McCollum is offline
[Insert Name Here]
FRC #0159 (Alpine Robotics)
Rookie Year: 2015
Thayer McCollum will become famous soon enoughThayer McCollum will become famous soon enough
Re: Rivnut Tool
I did not know these were a thing. But let me tell you they have made my day and I fully intend to use them where I can now that I know about them. So thank you guys.
Old 10-29-2016, 04:27 PM
ClockworkGold's Avatar
ClockworkGold ClockworkGold is offline
Wears Sparkly Gold Pants
AKA: Andrew F.
FRC #2169 (KING TeC)
ClockworkGold is a splendid one to beholdClockworkGold is a splendid one to beholdClockworkGold is a splendid one to beholdClockworkGold is a splendid one to beholdClockworkGold is a splendid one to beholdClockworkGold is a splendid one to behold
Re: Rivnut Tool
One of the ways we've used rivet nuts recently is to fasten our bumper frame to the chassis. On opposite sides, we have four 1/4-20 bolts spanning through the c-channel, 2x1x0.1 tube spacers, and into the threaded rivet nut.
Here is a top view
Here is a better angle
We also use the hand tool. We keep all of our rivet nuts in a special box with the gun.
2014: FRC 2169 Scouting and Spirit & FTC 7897 CAD
2015: FRC 2169 CAD, Strategy, Scouting & FTC Mentor 3385, 3387, 4509, 7899, 7900
Last edited by ClockworkGold : 10-30-2016 at 12:49 AM. Reason: Image 2 went to the imgur gallery, not the pic (better for mobile users)
Old 12-22-2016, 01:07 PM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Rivnut Tool
Thanks for sharing! We have purchased a possibly identical tool and some 10-32 inserts from Hanson rivet. Before we use it, I'd like to ask a few questions.
What sort of error? How can we eliminate or at least reduce this error?
The tool we purchased pulls on the mandrel/bolt linearly, not through torque applied to the threads on the insert. Does pulling it this way result in a good set, or does the buckled part of the wall tend to twist under the torque?
We purchased steel inserts. Has anyone used the aluminum ones, and if so, what have you used them for, and how have they held up? Using a threaded aluminum fastener to secure a chassis or mount a manipulator sounds like a stretch.
Finally, the tool we have has several adjustments in order to fit the specific insert being used, particularly the mandrel extension distance. As we have only purchased a single size insert so far, this should not be an issue, but if you use multiple sizes, how successful have you been at getting students to do the adjustments whenever they change from one size to another?
Edit (addition):
[pics]
Are the c-channel and tube spacers part of the bumper? How about the corner brackets?
We will also have a box just for the riveter, inserts, and the less-common sized drill bits needed for these inserts.
Old 12-22-2016, 01:34 PM
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Re: Rivnut Tool
Always wanted to use Rivnuts and found this tool recently, thoughts?
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Old 12-22-2016, 02:26 PM
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Re: Rivnut Tool
It's tough to tell from the picture, but it doesn't look nearly as sturdy as the one I linked above. The reviews on Amazon appear to support this - even the best review I read (****0) provided rather weak, qualified praise for the tool.
Old 12-22-2016, 02:43 PM
Bpk9p4's Avatar
FRC #1756
Re: Rivnut Tool
[quote=GeeTwo;1622947]Thanks for sharing! We have purchased a possibly identical tool and some 10-32 inserts from Hanson rivet. Before we use it, I'd like to ask a few questions.
The error we have is it takes a lot of hand/arm strength to set them this causes two problems.
1) They do not get properly set
2) if they do get properly they rarely are set perpendicular to the hole. This is due to them just struggling to get them set
we ended up buying a air rivnut gun. Once we test it some more i will let everyone know how it worked out
Old 12-22-2016, 02:44 PM
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Rivnut Tool
We use rivnuts a bit, and use both aluminum and steel rivnuts. Aluminum ones are easy to install with a manual tool, and easier to replace than steel rivnuts. Steel ones appear to be a bit stronger than aluminum ones, obviously, but sizing the grip length properly keeps installation effort down.
Where it makes sense to, we use a clinch/PEM nut. They can be installed with an impact driver and a bolt, a machine vise, a press, or even a hammer if you're really hard-up (not recommended, but it works...). They are ~1/2 the cost of a rivnut and leave the clamping face of the part nice and flat. Their only real downsides are that they can't effectively be installed into some blind-hole applications such as the middle of a long tube, and require a tighter hole diameter tolerance than rivnuts.
My point is that if you're using rivnuts already it's only a small leap to get into PEM nuts which area cheaper, stronger, and offer different low-effort installation options without the need for any specialized tooling. We use both on our robots.
Here's a shot of our 2015 robot where you can see the use of a few steel rivnuts to anchor a transmission (the rivnut head fit nicely inside the hex relief on the transmission housing) and PEM nuts on the chassis brackets. Steel rivnuts worked well for the transmissions: strong enough, nice thread lead-in, plenty of back-side spacing to fit them, not too many to install, and installed into a plasma-cut and post-machined plate (loose-ish tolerances). The PEM nuts worked brilliantly on the brackets: short enough to fit together, installed two at a time in a machine vise, loads of strength.
In our 2016 our ransmissions were thru-bolted because that made more sense, axle bearings were retained with PEM nuts because of their low profile, the bellypan was anchored with aluminum rivnuts which were strong enough and super-easy to install, and the shoulder tube (that provided a majority of the chassis strength) was anchored to the chassis with 6x PEM-nut fasteners per side.
Old 12-22-2016, 02:55 PM
Seth Mallory Seth Mallory is offline
FRC #0192 (GRT)
Seth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond repute
Re: Rivnut Tool
I do not recommended this tool. I have owned one of that construction and I hate it . All of that style at work, that includes the 4-6 that work buys a year, the round shaft comes loose over time and is frustrating to use. The tool from hansen is much better.
KF6UZX
Old 12-22-2016, 04:01 PM
Forhire Forhire is offline
AKA: Randy Smith
FRC #4060 (S.W.A.G. 4060)
Rookie Year: 2015
Forhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond repute
Re: Rivnut Tool
+1 for the PEM captive nuts. I use a lot of broach style and they are great. You can buy them from McMaster-Carr. https://www.mcmaster.com/#captive-nuts/=15l08yk
If you need large quantity I'd recommend S.W. Anderson http://www.swaco.com/ They can supply bulk bags for a fraction of McMaster.
For setting steel rivnuts I like the LEM tool. I have a set from #6 to 1/4. I haven't tried their spiral action speed header but it looks interesting. I've never set captive nuts with my LEM tool but it would likely work. http://www.lemtools.com/tools.php
Old 12-26-2016, 10:21 PM
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Re: Rivnut Tool
For the benefit of any who are considering whether to invest in trying rivnuts, here's my experience so far (first order received a few days ago).
I ordered the PNT-110 and a bag of SKL10-32-130 STEEL THIN-NUTs from Hanson Rivets. The web page for the inserts (rivnuts) specified a "grip range" of 0.02" to 0.13". As our primary use case is with 1/8" (0.0125") aluminum, and the secondary case is with thinner aluminum or steel, this seemed to be a minimal investment (less than $100) for a tool and a couple hundred inserts. While doing my Christmas shopping, I picked up a couple of 19/64" drill bits at Lowe's.
Saturday morning (yes, Christmas Eve, and my son's birthday), I drilled a hole in a piece of 1/8" aluminum bar and tried to set a rivnut in it. I tweaked the nose piece and used arm strength as well as hands, and even tried using the setter as a wrench on the threads, but I could not seem to get the insert to properly set. The insert seemed slightly swollen, but not set as a proper "rivet". For details, see the image, particularly the rivnut at the top, second from the right.
This morning (26 Dec), I had a bit of time to try a few things. My intention was to do a "pullout" test but this morning I decided to try a couple of other things first. I put an insert on the tool, and tried to set it in air. I am happy to report that this takes no more hand strength than a 3/8" rivet. The results are in the picture, third from right.
Then, I tried setting one of these rivnuts in 1/16" aluminum. I had a scrap of plywood edge channel handy, and the result is shown in the image at the far left.
I then did a few measurements of compressed and uncompressed inserts, and I am convinced that a '.130"' nut is only good for 1/8", or possibly 3/16" of material. I have ordered some rivnuts that support up to .225" thick, which should work quite well in 1/8" aluminum. 'll post some upgrades as I learn more.
Last edited by GeeTwo : 12-26-2016 at 10:24 PM. Reason: removed duplicate sentence
