Re: pneumatic catapults
This is a bit of a tangent, but what do people typically use as the fulcrum in the catapult? Do you just drill holes and run a strong bolt through, or do you incorporate bearings and go with something a bit more engineered? In 2014, we had an excessively overpowered kicker (A poor design led to us putting a dangerous amount of power into that kick.) that ended up bending several rods we were using as fulcrums. The hardstop was actually between the fulcrum rod and where our surgical tubing was mounted, so when the kicker arm hit the hardstop, the kicker arm applied a pretty large amount of side loading on the intended fulcrum rod because the corner of the hardstop began acting as the fulcrum whenever it hit the hardstop.
So long story short, what methods do you all use to mount the catapult arm and/or use as a fulcrum? |
3/4" bore 5" stroke cylinders i believe. |
This year, we used ball bearings, more out of the simplicity of doing so with versaframe than any requirement. Most years, we have used steel bolt(s) with bronze bushings.
Piano Hinge. Works great for a lot of applications.
Had it been a made in our shop we might have used bushings or bearings as a pivot. |
