Go to Post Let's sheathe the pitchforks and douse the torches for another two months, shall we? - Taylor [more]
Unread 10-28-2016, 05:46 PM
Yildirim Yildirim is offline
FRC #6429
Yildirim is an unknown quantity at this point
Pneumatics with command based programming
Hello everyone I am from team 6429 this is our forst year in FRC and I am the programmer I am doing command based programming it was going well until the pneumatics showed their faces to me I do not know how to control pneumatics (single solenoid) on command based programming. I have short time to finish program so I need a quick help pls. Also I am using java.
Unread 10-28-2016, 08:59 PM
GoldenGollem's Avatar
GoldenGollem GoldenGollem is offline
Java Programmer
FRC #2509 (Hutchinson Tigerbots)
Rookie Year: 2015
GoldenGollem is an unknown quantity at this point
Re: Pneumatics with command based programming
Do you have some of the code to post or any snipbit of it to show.
GoldenGollem -Hutchinson Tigerbots 2509
2015 - Mini-MN Regional 2nd Place Finalist
2016 - Mini-MN Regional 1st Place Finalist
Unread 10-28-2016, 11:02 PM
Penchant Penchant is offline
FRC #4607
Rookie Year: 2015
Penchant has a spectacular aura aboutPenchant has a spectacular aura about
WPI Screensteps is very helpful for things like this, including their page on solenoids here.
Unread 10-29-2016, 04:43 AM
FRC #6429
This is my subsystem's "wrist" code:
package org.usfirst.frc123.pnmatik.subsystems;
import org.usfirst.frc123.pnmatik.RobotMap;
import org.usfirst.frc123.pnmatik.commands.*;
import edu.wpi.first.wpilibj.Compressor;
import edu.wpi.first.wpilibj.Solenoid;
import edu.wpi.first.wpilibj.command.Subsystem;
public class Wrist extends Subsystem {
// BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=CONSTANTS
// END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=CONSTANTS
// BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=DECLARATİONS
private final Compressor compressor1 = RobotMap.wristCompressor1;
private final Solenoid solenoid1 = RobotMap.wristSolenoid1;
// END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=DECLARATİONS
// Put methods for controlling this subsystem
// here. Call these from Commands.
public Compressor getCompressor1() {
return compressor1;
public Solenoid getSolenoid1() {
return solenoid1;
public void initDefaultCommand() {
// BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=DEFAULT_COMMAND
// END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=DEFAULT_COMMAND
// Set the default command for a subsystem here.
// setDefaultCommand(new MySpecialCommand());
And this is the command's "Raise Wrist" code:
// RobotBuilder Version: 2.0
// This file was generated by RobotBuilder. It contains sections of
// code that are automatically generated and assigned by robotbuilder.
// These sections will be updated in the future when you export to
// Java from RobotBuilder. Do not put any code or make any change in
// the blocks indicating autogenerated code or it will be lost on an
// update. Deleting the comments indicating the section will prevent
// it from being updated in the future.
package org.usfirst.frc123.pnmatik.commands;
import edu.wpi.first.wpilibj.command.Command;
import org.usfirst.frc123.pnmatik.Robot;
public class RaiseWrist extends Command {
// BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=VARİABLE_DECLARATİONS
// END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=VARİABLE_DECLARATİONS
// BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=CONSTRUCTOR
public RaiseWrist() {
// END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=CONSTRUCTOR
// BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=VARİABLE_SETTİNG
// END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=VARİABLE_SETTİNG
// BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=REQUİRES
requires(Robot.wrist);
// END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=REQUİRES
// Called just before this Command runs the first time
protected void initialize() {
// Called repeatedly when this Command is scheduled to run
protected void execute() {
// Make this return true when this Command no longer needs to run execute()
protected boolean isFinished() {
return false;
// Called once after isFinished returns true
protected void end() {
// Called when another command which requires one or more of the same
// subsystems is scheduled to run
protected void interrupted() {
So what am i going to write and where (I think I should write the code to the execute in command) and am I need to write something t o subsytems actually I have no idea about pneumatics on command based programing as I said .
Thanks for your helps.
Unread 10-29-2016, 07:05 PM
bankst's Avatar
bankst bankst is offline
FRC #0832 (OSCAR)
bankst is an unknown quantity at this point
Going off the assumption you are using a Single solenoid (rather than a double), here is what I would put in 'execute':
RobotMap.wristSolenoid1.set(true); // open solenoid
And in the 'end' function:
RobotMap.wristSolenoid1.set(false); // close solenoid
Also make sure in the 'interrupted' function you put:
 end(); // close solenoid if command is interrupted
If you have any more questions about command-based programming let me know and I'd be more than happy to help.
2012-Present 832 Oscar (Alumni and Mentor)
Oscar's Website: http://oscarrobotics.meshnet0.com
Unread 10-30-2016, 05:54 AM
FRC #6429
Thank you very very much
