Go to Post But on the plus side, we can drive the robot with a DDR pad, which is crazy-stupid-cool. - Not2B [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Old 18-10-2016, 01:41
Re: R Package for Downloading FIRST API Data
Originally Posted by sirwin View Post
my solution is posted at https://irwinsnet.github.io/opr.html.
My method requires 13 seconds on a Surface 4 with an i5 process and 8 Gb of memory.
Reps to you for all the fine work
Reps to the first person who can cut that time in half.
Old 19-10-2016, 06:36
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Cut 13 seconds in half? I'm excited that sirwin got it to work at all on that data set! At 13 seconds, the WOPR rankings can be recalculated between matches before the first verse of "Cotton eye Joe" gets played.
Good job sirwin on the code, and an even better write up of how you did it.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Old 19-10-2016, 08:57
sirwin sirwin is offline
AKA: Stacy Irwin
FRC #1318 (Issaquah Robotics Society)
Rookie Year: 2016
sirwin is a glorious beacon of lightsirwin is a glorious beacon of lightsirwin is a glorious beacon of lightsirwin is a glorious beacon of lightsirwin is a glorious beacon of lightsirwin is a glorious beacon of light
With respect to speeding up the calculation, I had a thought.
It takes my algorithm 9 seconds to produce the 2696 x 2696 A matrix -- but updating the A matrix with new match data should be nearly instantaneous. For every new match, we just have to add 1 to 18 different elements in the A matrix (all other A matrix elements will remain unchanged). Each element of the a matrix is directly accessible by team numbers. So it takes 13 seconds to calculate world OPR from scratch, but as long as we retain the A matrix, it should only take about 5 seconds to update world OPR with new match data. That's 2 seconds for updating the A and B matrices and 3 seconds for solving for OPR.
Of course, this is assuming that R's underlying C code doesn't do anything stupid, like extracting an array element by going through every array element until it gets to the right one. Also, the A matrix would need to be maintained in memory -- disk access would slow things down.
Old 19-10-2016, 12:26
I like to call that symmetric positive definite 2696x2696 normal equations matrix the N matrix... to distinguish it from the 17842x2696 dichotomous design matrix A.
Ax = b .. overdetermined system of linear equations (has no exact solution)
N = A'*A
d = A'*b
Nx = d .. linear system of normal equations (whose solution is the least squares solution for Ax=b)
Old 19-10-2016, 18:50
OK, I was being generous. Cut it by a factor of 10. Seriously.
Old 23-10-2016, 16:48
If there is any interest in learning how to do this within the R community please let me know and we can work it out together.
Old 25-10-2016, 15:31
Joey1939's Avatar
Joey1939 Joey1939 is offline
AKA: Joey Holliday
FRC #1939 (Kuhnigits)
Joey1939 has a spectacular aura aboutJoey1939 has a spectacular aura aboutJoey1939 has a spectacular aura about
I took the world OPR data and made a graph.
EDIT: I made a better graph.
Name:	OPR Distribution 2.png
Old 29-10-2016, 11:24
https://www.chiefdelphi.com/forums/s...09#post1614009
Old 31-12-2016, 12:30
AKA: Stacy Irwin
Rookie Year: 2016
I created version 2.0.0 of the firstapiR package for downloading and manipulating FIRST API scouting data using the R language.
Here's a link:
http://irwinsnet.github.io
Once I started using the package to do OPR calculations, I realized it needed some improvements, specifically in how the data frames are shaped.
Stacy Irwin
Old 31-12-2016, 16:48
@ Stacy: thanks for posting this. I just send you a PM.
Old 31-12-2016, 20:45
Skyehawk's Avatar
Skyehawk Skyehawk is offline
Nuts N' Bolts
AKA: Skye Leake
FRC #0876 (Thunder Robotics)
Skyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to all
My method requires 13 seconds on a Surface 4 with an i5 process and 8 Gb of memory. It actually takes more time to create the A matrix (9 seconds) than it does to solve for the OPRs once the A and B matrices are prepared (3 seconds). The remaining second is required for reading the data and preparing the B matrix.
Stacy
I am aware I am beating a dead horse here , but using unmodified Sirwin's code I am getting ~12 seconds with an i7-6560U (2.2GHz) and 8gb of RAM, memory usage is low so we can eliminate that as a factor. The bottleneck is (unsurprisingly) CPU clock cycle speed.
I'm using firstapiR v2.0.0
Skye Leake
My time in FIRST has made me a better person, frankly I don't know where I'd be without it.
2011 Lake Superior Regional Champs
2015 Central Illinois Regional Engineering Inspiration Award recipients
2016 Central Illinois Regional Champs
Old 31-12-2016, 21:11
I am getting ~0.93 seconds on a 10-year-old Pentium D desktop running 32-bit XP with 1G RAM.
Old 31-12-2016, 21:24
Skyehawk's Avatar
Nuts N' Bolts
AKA: Skye Leake
I obviously am doing something not quite right...
Old 31-12-2016, 21:26
Your results look about right for R code that uses dense matrix technology.
https://www.chiefdelphi.com/forums/s....php?p=1612297
https://www.chiefdelphi.com/forums/s....php?p=1612581
https://www.chiefdelphi.com/forums/s....php?p=1613118
https://www.chiefdelphi.com/forums/s....php?p=1614125
Old 01-01-2017, 11:50
Conor Ryan Conor Ryan is online now
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
In case anybody wants to learn R, here is a great way to get introduced http://swirlstats.com
Last edited by Conor Ryan : 01-01-2017 at 11:51. Reason: It's what we use when building models!
[IMG] code is Off
