Go to Post Even with everyone using the same RC setup, teams still botch it in many creative ways. - Wetzel [more]
Unread 29-10-2016, 16:43
RyZeRun RyZeRun is offline
FRC #4104
RyZeRun is an unknown quantity at this point
Question Syntax for 'virtual void GetDescription'?
The WPILib documentation won't explain it well enough for me. It says:
virtual void GetDescription (std:stringstream &desc) const =0
I have no idea what the 'std:stringstream &desc' and 'const =0' parts mean. Can someone explain?
Unread 29-10-2016, 16:46
FRC #4104
Re: Syntax for 'virtual void GetDescription'?
Some of my post was accidentally converted to an Emoji.
I MEANT 'std::ostringstream &desc'
Unread 29-10-2016, 18:08
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Which class is this method from?
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 29-10-2016, 18:13
I MEANT 'std:stringstream &desc'
What are you trying to do? Can you share the code that triggered this error?
GetDescription takes a reference to an ostringstream.
const = 0 means that the method is pure virtual (ie, it must be implemented in subclasses). So, you are trying to do something with an interface, not the implementation.
Unread 29-10-2016, 18:54
Jared Russell's Avatar
Taking a year (mostly) off
virtual void GetDescription (std::ostringstream &desc) const =0
Piece by piece:
virtual
This means that the function is virtual. Derived classes can provide a function with the same signature that will be called instead even if you call the function through a reference or pointer to the base class. Read more here.
void
This is the return type. "void" means the function doesn't return anything.
GetDescription
This is the function name.
The function takes a single argument (with the name "desc") of type "std:: ostringstream &". An ostringsteam is an output stream that operates on strings. String streams are useful for building strings piece-by-piece (normal C++ strings are immutable, so if you build a string by concatenating smaller strings together, you do a lot of object creation and deletion, which is inefficient). The "&" means that the parameter is passed by reference. See here for more info on the various ways you can pass arguments.
const
This means that the function is not allowed to change any internal class members (if you try, you'll get a compile error unless you use a const_cast to override this).
=0
This part is an addendum onto "virtual"...it further means that this function is "pure virtual". This means that this class is an abstract and cannot be instantiated. What good is a class that can't be instantiated? Well, you can have other classes that inherit from this one, and they can supply their own implementation of this method (in fact, they need to, otherwise they are also abstract).
