Go to Post Sometimes, having someone that can teach you just shows you another way to do what you've been doing, but in fewer moves. - Amanda Morrison [more]
Unread 30-10-2016, 05:54
Yildirim Yildirim is offline
FRC #6429
Yildirim is an unknown quantity at this point
Re: Pneumatics with command based programming
Originally Posted by bankst View Post
Going off the assumption you are using a Single solenoid (rather than a double), here is what I would put in 'execute':
RobotMap.wristSolenoid1.set(true); // open solenoid
And in the 'end' function:
RobotMap.wristSolenoid1.set(false); // close solenoid
Also make sure in the 'interrupted' function you put:
 end(); // close solenoid if command is interrupted
If you have any more questions about command-based programming let me know and I'd be more than happy to help.
Thank you very very much
