Go to Post Your primary job is not to build the most technically advanced robot, but build the best possible team. - PayneTrain [more]
Unread 31-10-2016, 05:11
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Re: pneumatic catapults
Originally Posted by Knufire View Post
There used to be a rule that limited the Cv (flow coefficient) of solenoid valves on the robot, causing the solenoid to be a bottleneck in the flow path. That rule has since been removed. However, larger Cv solenoid valves are generally larger and/or heavier, so multiple cylinders on multiple solenoids may be a good alternative depending on your design constraints.
To continue on this (sorry, too used to thinking electrical) the other counterpart to this is we are still constrained by the pneumatic size limits which act as an indirect Cv limiter. A fitting and tube withing the existing 1/8th inch port and 0.165 inch inner diameter limit your maximum air flow for each path the air takes.
By the way, watch out for the Cv rating on components. We've seen some come in where the solenoid was advertised at one Cv rating, but the fixtures had only a tiny hole for air to pass through and so the effective Cv rating was significantly smaller.
