Go to Post To sum it up... We know nothing. - BJC [more]
Unread 31-10-2016, 07:50
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Re: Ports changed independently?
Check the can buss for issues, look for retry counts, (I think the are on the same status page, going from memory) make sure you have the can wired correctly, with terminating resistors at each end, and daisy chained through the devices.
When Setting device id's make sure you use the "Flash LED" command to identify the correct talon srx before setting the id and buss number. Quite common to setting the id to another SRX than the one you wanted.
The sooner we get behind schedule, the more time we have to catch up.
