Go to Post This is a risk. Life is full of risks. FIRST is life... therefore, FIRST is full of risks. - Andy Baker [more]
Unread 31-10-2016, 08:19
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
JAVA 101 help
As a complete novice with JAVA I am trying some sample tests to get some sort of handle on how to program in this language.
Please see the below code
import java.util.Scanner;
public class makeitwork {
static Scanner scanner = new Scanner(System.in);
public static void main(String[] args) {
Boolean alarm = false;
System.out.println("What time 0-24");
Integer clock = Integer.parseInt(scanner.nextLine());
System.out.println("Door open 'T' or 'F'");
String door = (scanner.nextLine());
System.out.println("Test combo 0000-9999");
String combo = (scanner.nextLine());
System.out.println("#1-t-"+clock+"-d-"+door+"-c-"+combo+"-a-"+alarm);
if (clock < 5){
System.out.println("clock<5");
if (clock == 5){
System.out.println("clock = 5");
if (clock >5 && clock <24){
System.out.println("clock > 5 and < 24");
if (clock >5 || clock <24){ // watch out for this one it only fails with 24
System.out.println("clock > 5 or < 24");
if (clock >=23 && clock <=24 || clock>= 0 && clock <= 3){
System.out.println("clock 11pm to 3 am");
// all those integer functions seem to work on clock.
// lets see what work for strings
if (door == "t"){
System.out.println("It's a t");
else{
System.out.println("Don't know-"+door+"-");
} //end of main
}// end of public
The integer functions seem to work just as expected but when I try the same thing with what I think is a string it does not work at all. The print will always be "Don't know-"+door+"-" result.
So my question(s) are;
What am I doing wrong?
Where in the "eclipse" enviroment can I find example help on functions?
When using the 'Help' function in eclipse what does one do to get a list functions?
Currently I am looking for way of finding things out about a string such as;
1)it's length
2)how to strip a string apart one charater at a time and search for delimiters etc.
for example;
assume test[] are strings
test = "334,5,t,678,c,9"
from the 'test' I would like to extract the string parts separted by a ','
to get
test1 = "334"
test2 = "5"
test3 = "t"
test4 = "678"
test5 = "c"
test6 = "9"
Many thanks
