Go to Post For Pete's sake, don't concentrate on the entry itself... concentrate on what your team is doing to make an impact in your community. - Andy Baker [more]
Unread 10-31-2016, 11:28 AM
RyZeRun RyZeRun is offline
FRC #4104
RyZeRun is an unknown quantity at this point
"Getting Started" Errors
I created a WPILib example file, "Getting Started". This is my code:
#include "WPILib.h"
class Robot: public IterativeRobot
	RobotDrive myRobot; // robot drive system
	Joystick stick; // only joystick
	LiveWindow *lw;
	int autoLoopCounter;
public:
	Robot() :
		myRobot(0, 1),	// these must be initialized in the same order
		stick(0),		// as they are declared above.
		lw(LiveWindow::GetInstance()),
		autoLoopCounter(0)
		myRobot.SetExpiration(0.1);
private:
	void AutonomousInit()
		autoLoopCounter = 0;
	void AutonomousPeriodic()
		if(autoLoopCounter < 100) //Check if we've completed 100 loops (approximately 2 seconds)
			myRobot.Drive(-0.5, 0.0); 	// drive forwards half speed
			autoLoopCounter++;
			} else {
			myRobot.Drive(0.0, 0.0); 	// stop robot
	void TeleopInit()
	void TeleopPeriodic()
		myRobot.ArcadeDrive(stick); // drive with arcade style (use right stick)
	void TestPeriodic()
		lw->Run();
START_ROBOT_CLASS(Robot)
I get five errors:
- Program "C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\bin\amd64\cl" not found in PATH
- The type 'Joystick' must implement the inherited pure virtual method 'GenericHID::GetPOV' In line 7
- The type 'Joystick' must implement the inherited pure virtual method 'GenericHID::GetRawAxis' In line 7
- The type 'Joystick' must implement the inherited pure virtual method 'GenericHID::GetRawButton' In line 7
- The type 'RobotDrive' must implement the inherited pure virtual method 'MotorSafety::GetDescription' In line 6
Also, 'START_ROBOT_CLASS(Robot)' has a syntax error.
How can I fix these errors?
