Go to Post So does this mean we can use the FP as bumpers? :D - Peter Matteson [more]
Go Back   Chief Delphi > Competition > Regional Competitions
Unread 31-10-2016, 11:20
bobbysq bobbysq is offline
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
Defense pins?
Does anyone know what type of hardware the defense pins were? We recently got ahold of some official defenses and would like to know how to hold them in place.
Unread 31-10-2016, 11:30
Re: Defense pins?
FIRST HQ used "S" hooks from peg boards. This kind of hook
Some Districts (MAR) used simple threaded hardened bolts-threaded all the way to the head/no smooth shank (loose in the hole not screwed in).
Unread 31-10-2016, 11:55
Nate Laverdure's Avatar
FRC #2363
Re: Defense pins?
Curved J-Hooks for Pegboard - 5/8" - U-LINE H-2694
Unread 31-10-2016, 11:58
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Re: Defense pins?
Some Districts (MAR) used simple threaded hardened bolts (loose in the hole not screwed in).
Did the bolts hold up any better than the hooks?
Unread 31-10-2016, 12:15
Re: Defense pins?
The bolts hold better because the threads catch and hold, while the peg board hooks are softer metal and gradually stretch out and have to be replaced.
The peg board hooks sometimes need to be cut out when they get shoved into an awkward position, while the bolts can usually be unscrewed if necessary.
But the hardened bolts do gradually enlarge the holes in the defenses, so if you're planning to use the defenses many times the holes will get damaged by repeated use of the bolts.
Unread 31-10-2016, 12:18
marshall's Avatar
Re: Defense pins?
I genuinely appreciate that thorough explanation of the pros and cons of defense retaining fastener selection. Thank you!
Unread 31-10-2016, 12:44
Re: Defense pins?
There are other nuances where the pegboard hook can be more effective than the straight bolt in holding a particular style defense down, but a lot of that depends on how the robots are interacting or lifting the defenses.
There are also variations that can work even better like tying down the S hooks if the defense will never be moved or replaced, e.g., low bars.
Unread 31-10-2016, 14:07
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
Re: Defense pins?
The bolts worked great until they started enlarging the holes, as Mark said. During the season, the bolts would occasionally get jammed at an odd angle if a defense was hit hard, but it didn't happen often and even in that scenario they were pretty easy to take out using a drill with a hex bit (from my experience). But, they didn't deform or break like the hooks.
However, at this point in the off-season, some of the MAR defenses that typically get hit the hardest during the match (moat, rock wall) have holes too large for the bolts to keep the defenses securely in place during a match. We're looking at drilling new holes for Ramp Riot this weekend because of the issues they had at the last event.
If the defenses you acquired have holes that are still approximately circle-shaped, you'd probably be fine with using bolts. I doubt that one robot using the defenses for practice/demos (which is what I'm assuming you'd be doing) would cause the holes to enlarge to an unusable point before you decide to retire the robot
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
Unread 31-10-2016, 14:38
marshall's Avatar
Re: Defense pins?
Sadly not, genuinely just curious because all I ever saw were the hooks and they definitely didn't hold up.
Unread 31-10-2016, 15:47
Michael Kaurich's Avatar
Michael Kaurich Michael Kaurich is offline
RoboRoadie-Maryland/DC
FRC #6326 (Baltimore Bolts)
Michael Kaurich is a jewel in the roughMichael Kaurich is a jewel in the roughMichael Kaurich is a jewel in the rough
Re: Defense pins?
Just make sure to have a set of bolt cutters on hand if you are looking to swap the defenses out. It is easier to cut a 10 cent bolt/hook than spend the time trying to get the things out of the holes.
Unread 31-10-2016, 16:08
Rookie Year: 2015
Re: Defense pins?
So if my team were to get the hooks, (which I doubt we will, since we have plenty of 1/4-20 bolts laying around) how would we put them in?
Unread 31-10-2016, 16:36
Re: Defense pins?
Think of the hole in the defense as a pegboard and insert the pegboard end of the hook into the hole.
Swing the hook to the side out of the way.
Unread 31-10-2016, 20:20
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Re: Defense pins?
This part is really important, especially on the Cheval-de-Fries. At Battle for the Bluegrass, I noticed that if the hook part was facing inwards, the corner of the outermost sections could get caught under the hook and stay in that position. Granted, this was with the holes looking rather oval-ish, but it was something the field reset crew had to check each match.
