Go to Post Put on shows. Start new teams, FRC, FVC, or FLL. It doesn't matter. But I know that being on the robotics team has given me some of the best memories of my life, and I wouldn't want anybody else to miss out on that. - irishninja [more]
Unread 10-31-2016, 12:28 PM
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
What hath we wrought? 2016 Horror Stories
After & During the 2016 season I've come across a number of horror stories of all sorts from the fields.
Teams learned how good their wiring was and how tough a field could be on robots.
FIRST learned a bit about the monsters they've brought forth by the damage to the fields.
I've heard of batteries winding up feet away from robots after a crossing. I've been at an event where a robot left the field (and the e-stop button failed).
What have you seen this past season?
Unread 10-31-2016, 12:56 PM
Bryce Clegg's Avatar
Bryce Clegg Bryce Clegg is offline
FRC #3196 (Team SPORK)
Bryce Clegg is on a distinguished road
Re: What hath we wrought? 2016 Horror Stories
I know that all the competitions I went to in North Carolina they put all the small parts from the robots that came apart in a table off the field. Also, I witnessed a robot smoking after the match ended and the robot tried to stay up for the scale.
For our team, we didn't protect our mini-cims and the end where the wires come out of popped off. I believe this happened because of the step to keep the robots on for the capture. We ended up putting tape on it to keep it together, and it still worked.
Many a time I saw the zipties pop off and lexan decorations forcefully removed from the sally port by too-wide robots.
Deans List Semi-Finalist 2016
"I'm not going to tell you all that you all are winners. At this point you are smart enough to know whether you are or you aren't." - Woodie Flowers
Unread 10-31-2016, 01:02 PM
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
I'm still impressed with the way this output shaft sheared at MAR Champs.
Unread 10-31-2016, 03:43 PM
OccamzRazor's Avatar
OccamzRazor OccamzRazor is offline
Go YETI!
AKA: Robbie
FRC #3506 (YETI)
OccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to behold
Yeah I think you witnessed us smoking after the match. Asheville was not kind to us. Our climber gearbox decided it was done after about 60 climbs so we used our backup from then until Champs. Still managed not to hit the carpet and foil the capture!
2015 NC Regional Chairman's Award
2016 NC Guilford District Event Winner
2016 NC Guilford District Chairman's Award
2016 NC District Championship Winner
2016 NC Regional Chairman's Award
2016 NC Woodie Flowers Award Finalist - Lia Schwinghammer
Unread 10-31-2016, 04:04 PM
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
We learned that the proliferation of 3D printed parts in 2015 should not have been copied in 2016.
We broke some custom intake rollers (in all fairness, after 2 regionals and some heavy contact)
We also bent/destroyed our intake roller shaft (0.5'' steel bent at about a 10deg angle at the midpoint) during a collision with Team 179 at Champs... I think they broke too.
Oh, and the chains... so many broken chains...
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 10-31-2016, 05:03 PM
StAxis's Avatar
StAxis StAxis is offline
Mentor/Drive Coach
AKA: Zach CH
FRC #1902 (Exploding Bacon)
StAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud of
It didn't happen till the off season, but we completely destroyed a ball shifter gear. Other damage includes innumerable broken chains, 3 destroyed intake plates, and a bent frame rail.
https://imgur.com/a/JLzT2
The gear on the other side hasn't lost any teeth yet but is showing a pretty bad wear pattern so we're replacing both.
Name:	1 - y2RSCYY.jpg
2012 - Engineering Inspiration SFL
2013 - Chairmans SFL, Regional winners SFL
2014 - Engineering Inspiration SFL
2015 - Chairmans GSCR
2016 - Chairmans Rocket City Regional
Unread 10-31-2016, 05:08 PM
Andrew_L's Avatar
Andrew_L Andrew_L is offline
#DriveSwerveEveryDay
AKA: Drübr Inc.
FRC #1323 (Madtown Robotics) #971 (Spartan Robotics)
Andrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud of
Is that 1/2" hex to 3/8" hex on the same shaft? Based on the shear it looks like the step up to a larger size may have helped make the near perfect shear point.
Unread 10-31-2016, 05:17 PM
bkahl's Avatar
bkahl bkahl is online now
Make Champs Great Again
AKA: Bailey Kahl
FRC #0125 (NUTRONS)
bkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond repute
Looks like the 5/8" step down to the 1/2" hex on the WCP Dog Shifter output shaft.
Regardless, this Step down is the exact spot to expect a failure on the part.
Team 125
College Student/Whatever Brando says
Team 195
Alumni
Facebook
EWCP
Unread 10-31-2016, 05:31 PM
Andrew_L's Avatar
AKA: Drübr Inc.
Gotcha - didn't see the slot at first.
Unread 10-31-2016, 06:10 PM
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Among all the carnage this years game produced, there were a couple things that made me smile, and a couple that made me cringe!
Who will ever forget the "Pole Wars"?
I witnessed a Defence attack a volunteer. I saw it roll up and smash her fingers right in front of me before I even had time to react. (Sorry, no pictures for that one. This is not the place for that.)
Auto was fascinating this year! While some teams were "grinding" out two ball Auto, others took a slightly more aggressive approach! More power, all the time! I saw more Driver's Stations on the ground this year than ever before!
I even saw one team that missed the memo that "Robots are NOT Points!"
This is where they ended up during Auto, and this is where they stayed all match.
This year's game was brutal for both Robots and the field it's self.
If you had a design flaw, this game would find it and show it to you, RIGHT IN YOUR FACE!!
Unread 10-31-2016, 06:31 PM
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Anyone who ran or helped run a competition understands the struggle of dealing with the defenses. Stronghold was cool, but it was a big logistical challenge.
As for failures, we've broken four 17t gears from the AndyMark Sonic Shifters (2 during the regular season). We have one more competition this year and hopefully we don't need any more because they appear to have been discontinued.
We also sheared a 1/2" steel drive shaft very early on in the season.
I hope we can go back to 4" or 6" wheels (aka a wheel size that were used to determine gear ratios for COTS transmissions) so that we don't keep breaking parts with unsuspected loads.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 10-31-2016, 06:33 PM
troy_dietz's Avatar
troy_dietz troy_dietz is offline
3D printing and Alliance Captain
FRC #0330 (The Beach Bots)
Team Role: Human Player
Rookie Year: 2015
troy_dietz is on a distinguished road
9330 during their second semifinals match at BeachBlitz.
We almost scored a low goal like this, but the right side of the intake hit the main breaker. We were able to aim reasonably well with the turret bolted back on for the finals, but that robot won't be scoring any time soon.
Unread 10-31-2016, 06:51 PM
Connor McBride's Avatar
Connor McBride Connor McBride is online now
I live my life 2:30 at a time!
Connor McBride will become famous soon enough
To add to this, we also cracked our beaver tail intake. It was so sad watching the robot drive as the intake flopped around.
FRC 166 2013-2016 (student) 2016-present (junior mentor)
NHTI VEX U 2016-present (treasurer)
Youtube Channel Team Page Facebook Page
Unread 10-31-2016, 07:51 PM
TheBoulderite's Avatar
TheBoulderite TheBoulderite is offline
Director of Communications
AKA: Warren Bartlett
FRC #1619 (Up-A-Creek Robotics)
Rookie Year: 2015
TheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond repute
One of my favorite ironies occurred at IRI this year when TechFire's motor started smoking on the field.
2015-now: 1619 (Up-A-Creek Robotics)
???: 2017 Utah Regional, ???: 2017 Colorado Regional
Thanks to all of our alliance partners over the years!
(1583, 1667, 937, 1332, 1158, 1348, 2543, 2261, 1777, 2240, 2036, 3648, 1410, 3200, 3807, 4550, 399, 2594, 1987, 4153, 624, 4334, 1730, 4593, 3618, 3026, 967, 4499, 3009, 1011, 525, 4028, 3352)
Unread 10-31-2016, 08:50 PM
It probably was you guys, it seemed like your robot successfully scaled almost every single match. Your robot was an amazing one to watch and compete against. I remember that at Asheville we were playing defense against you, and your robot hit the ground very hard, at the point where most robots would break. Then, you guys fixed the robot and won the next match.
