Go to Post Originality in Sponsorship can get you a lot of places. - MysterE [more]
Unread 31-10-2016, 16:58
MikePerreman's Avatar
MikePerreman MikePerreman is offline
FRC #0247
MikePerreman is an unknown quantity at this point
Exclamation Strange comms issues
alright, well, fresh install of the update suite, on the diagnostics screen, the radio appears as connected, and when im tethered over enet, i get comms, this is the cmd output when i ping it:
C:\Users\mikep>ping roborio-247-frc.local
Ping request could not find host roborio-247-frc.local. Please check the name and try again.
C:\Users\mikep>ipconfig
Windows IP Configuration
Ethernet adapter Ethernet:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . : lan
Ethernet adapter VirtualBox Host-Only Network:
Link-local IPv6 Address . . . . . : fe80::ede0:7663:b28:d0b%5
IPv4 Address. . . . . . . . . . . : 192.168.56.1
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . :
Wireless LAN adapter Local Area Connection* 2:
Wireless LAN adapter Wi-Fi:
Link-local IPv6 Address . . . . . : fe80::c03a:8389:bead:b33c%10
IPv4 Address. . . . . . . . . . . : 10.2.47.142
Default Gateway . . . . . . . . . : 10.2.47.129
Tunnel adapter isatap.{40AC7A55-92B6-4318-AE9A-E731FFE47791}:
Tunnel adapter Local Area Connection* 12:
Tunnel adapter isatap.lan:
C:\Users\mikep>
any help?
Programmer - A creature known for converting Caffeine into Code.
Unread 31-10-2016, 17:09
Re: Strange comms issues
Are you saying the Driver Station connects correctly via Ethernet, but not via wireless?
Has your robot radio been reset for home use since your last competition?
Unread 02-11-2016, 08:06
FRC #0247
yup. over Ethernet, works just fine. ive (on the computer thats having the issues) re-imaged the radio, and updated the bot. wifi works just fine on everyone else's, it just me, although, it has worked in the past
Unread 02-11-2016, 09:01
It's your PC then, so have you tried disabling all those things that vary from PC to PC:
  • Windows Firewall
  • any and all anti-virus software
Check what IP your wireless connection gets assigned vs the Ethernet port to make sure it's compatible with the roboRIO.
The ipconfig you posted looks good for the wireless connection, but doesn't show what the Ethernet address would be when connected to the robot radio.
Unread 02-11-2016, 09:05
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Once you are connected to wifi, press the reset button on the RIO.
Unread 02-11-2016, 09:31
beijing_strbow beijing_strbow is offline
FRC #5968 (Cyborg Indians)
Rookie Year: 2016
beijing_strbow is an unknown quantity at this point
I had the same issue on my laptop. In the team number field in the driver station, enter roboRIO-####-FRC.lan (where #### is your team number). That fixed it for me.
Unread 02-11-2016, 09:41
In that team field in the Driver Station Setup tab that beijing_strbow mentioned, you can also click on the down arrow to get a list of the roboRIO's it has found and choose from that list.
Unread 03-11-2016, 13:54
Taggerun's Avatar
Taggerun Taggerun is offline
The Lone Programmer
FRC #3036 (DROBA Warriors)
Rookie Year: 2016
Taggerun is an unknown quantity at this point
Exclamation Re: Strange comms issues
If you are using Windows 10 try using an older version of Windows we had the same problem using Windows 10. Just a thought.
Good Luck,
Taggerun
My favorite robot?
The Aluminium Annihilator
"Oh yeah, it's British!!!!"
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
Unread 03-11-2016, 18:05
FRC #0247
alright, now, trying to download code, i get this:
Trying Target: roboRIO-247-FRC.local
Unknown host: roboRIO-247-FRC.local
entering roboRIO-247-FRC.local into the team number feild on the ds connects to the bot, however.
Unread 07-11-2016, 18:09
FRC #0247
hello? can i please get some help, ive done everything i can think of.
Unread 07-11-2016, 18:47
Did you follow the troubleshooting steps?
http://wpilib.screenstepslive.com/s/...roubleshooting
You can also try using .lan in place of .local for downloading code.
You can also connect via USB cable and use 172.22.11.2
Unread 07-11-2016, 18:55
FlamingSpork FlamingSpork is offline
Eating Utensil
FRC #3003 (Tan[X])
Rookie Year: 2015
FlamingSpork is just really niceFlamingSpork is just really niceFlamingSpork is just really niceFlamingSpork is just really niceFlamingSpork is just really nice
If you haven't re-configured your robot radio since your last event, you might need to do so. If you haven't re-configured it, the WiFi light on it will probably be red (or at least that's how it is on my team's robot).
http://wpilib.screenstepslive.com/s/...o-for-home-use
