Go to Post The game objectives are still the same, get boxes into your scoring zone, stack approximately half of them, run for the top of the ramp. So lets sit down, shut up, and start building robots. - ChrisH [more]
Unread 10-31-2016, 09:08 PM
TAlholm's Avatar
TAlholm TAlholm is offline
Mainely CAD
AKA: Tim Alholm
TAlholm is just really niceTAlholm is just really niceTAlholm is just really niceTAlholm is just really nice
Re: What hath we wrought? 2016 Horror Stories
Don't use a 14t gear in a 3 cim gearbox.
FRC Team 1991 (2013 - 2016) - Head of Design / Head of Scouting
Don't trust me to cut down a straight line, unless it's on an automated router or mill.
Unread 10-31-2016, 09:23 PM
ctt956 ctt956 is offline
Overanalyzing the Hints
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
'Nuff said.
Originally Posted by TheBoulderite View Post
One of my favorite ironies occurred at IRI this year when TechFire's motor started smoking on the field.
IIRC 2640(HOTBOTZ) had a drivetrain motor burn out during a match. Their robot was pretty good, and they fixed it quickly, but one whole side stopped working properly at DCMP. Still an amazing performance with a broken drivetrain.
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 10-31-2016, 10:30 PM
codedr codedr is offline
FRC #0537
codedr will become famous soon enoughcodedr will become famous soon enough
I learned that if the battery cables can be rocked back and forth at the battery or at breaker, they are too loose and will cause high current draws that shutdown the robot.
Same for the wires between the breaker and the power distribution board.
Add the bouncing over defenses, robot on robot contact, and loose power connectors to the radio either at the barrel plug or at the pdp and you get a dead robot.
If you can pull wires out of the pdp wago connector they are too loose.
Unread 11-01-2016, 12:28 AM
cscottm cscottm is offline
Crazy Person
FRC #2502 (Talon Robotics)
Rookie Year: 2015
cscottm will become famous soon enough
Our active got drove upon during a match at champs, more or less had to rebuild it. Same thing happened at Minnesota State.
I chose to rebuild it for IRI, and it was a very good call because 233 more or less made a giant dent in it.
Oh and lots of chain was harmed in this season.
Not to mention 3 stripped gears in the WCP Double Reduction gearbox (we broke 3/4 that we had(got put out of commission for 10K lakes regional))
Not to mention the match at champs where we had our rear bumper ripped off our robot https://youtu.be/6FG63S24z1g?t=85
Not to mention two matches where our bottom plate ripped out and dropped our battery.
And lots of melted pneumatic tubing as we were running the 98C which gets really hot.
Honorable Mention: https://youtu.be/DDm56AZgHf8?t=73
The time we drove on the top of 2052 at MRI
Unread 11-01-2016, 09:14 AM
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Originally Posted by SenorZ View Post
We learned that the proliferation of 3D printed parts in 2015 should not have been copied in 2016.
We broke some custom intake rollers (in all fairness, after 2 regionals and some heavy contact)
I think we've broken almost every 3D printed part on our robot at least once
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 11-01-2016, 09:31 AM
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
I'm surprised that nobody has mentioned the robot fire at Michigan State Champs yet.
Originally Posted by billbo911 View Post
I witnessed a Defence attack a volunteer. I saw it roll up and smash her fingers right in front of me before I even had time to react. (Sorry, no pictures for that one. This is not the place for that.)
Yeah. I could go with never seeing that again too
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
Unread 11-01-2016, 10:08 AM
bobbysq bobbysq is offline
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
I call this match "New Drivers Vs. Intake Rivets"
https://www.youtube.com/watch?v=Ly654puHgZc
This is a good lesson about planned failure points though. If we had used steel rivets instead of aluminum rivets to hold the tubes making up our intake together, the intake would have broken further along, and in a far harder to repair place.
Unread 11-01-2016, 10:20 AM
logank013's Avatar
logank013 logank013 is offline
Me: "Ready to scout?" Team: "Ughh!"
AKA: Logan Kreisher
FRC #0234 (Cyber Blue)
Team Role: Scout
Rookie Year: 2015
logank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant future
As you can see in the picture, 2781 flipped over, we (234) lost a bumper, and 461 dislodged a defense. I believe this all was in auto. Thank goodness, we were able to replay this match because of the field fault.
Edit: Also, all 3 of us are on the same alliance. This was at the off season event Boiler Bot Battle so correct colored bumpers were not required.
Cyber Blue Season 2015
IN Indy District Chairman's Award Winner | IN Kokomo District Event Winner (With 135 and 3865)
IN Purdue District Event Winner (With 1024 and 2197) | IN District Championship Winner (With 1024 and 292)
WORLDS:
Archimedes Rank 3 After Quals. | Alliance #3 Captain
Archimedes Division Semi-Finalist (With 503,188, and 836)
Scouting is life. Excel is friend, not foe.
Unread 11-01-2016, 10:27 AM
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
Unless those wires shorted to each other, that's probably not what was happening. Assuming everything was taped over as it should be per the rules and the inspection checklist, the loosening of your connections was increasing the resistance at those connections. Higher resistance with the same current (P=IR) means more power dissipated. More power dissipated means the main breaker heats up, and since it's a thermally tripped device, it opens faster shutting down your robot.
Either that or it's really loose and wiggly and you intermittently lose power. Even a fraction of a second will reset the RoboRIO and Radio.
It's a problem that pops up occasionally that often gets the attention of FTAs and Robot Inspectors due to the random shutdown. A bit of diligence when tightening and some lock washer (split, toothed, or other) will typically prevent such a problem. Although the extra pounding induced by the game this year may have challenged even those preventative measures.
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
Unread 11-01-2016, 10:36 AM
Tsukunea's Avatar
Tsukunea Tsukunea is online now
Lead Designer, Drive Coach
AKA: Boone Shangle
FRC #6065 (Titanium Dragons)
Team Role: CAD
Rookie Year: 2016
Tsukunea is on a distinguished road
About a week into October, the pancake on our gearbox decides to come unattached somehow. And second match at WMRI our robot's autonomous decided to go the wrong way and she ended up mounting one of the other teams' robots XD
B. Shangle
Lead Designer & Recruiter, Drive Coach of FRC Team 6065 "Titanium Dragons"
Kenowa Hills/Feyen Zylstra
Minister of Publications of Kenowa Hills Applied Technology & Design
"New Ideas for the World"
Unread 11-01-2016, 10:38 AM
Data Nerd
FRC #0079
Impressive, I don't think 125 broke any of the 3d printed parts on the bot last year. This included the entire intake roller being 3d printed.
Guess it just goes to show you that 3d printed parts aren't inherently weaker it's all in how you design and use them.
Unread 11-01-2016, 10:56 AM
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
We were relatively lucky. We only blew a few pneumatic tires and stripped out the plastic VEX versahubs.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 11-01-2016, 11:20 AM
Chris is me's Avatar
AKA: Pinecone
I mean, they are inherently weaker than injection molded parts - it's just a matter of if they are designed and built strong enough for the application. But your general point is right, I'm just being pedantic.
In general, this thread has many examples of design practices that are potentially fine being written off as universally bad ideas that can't work, or design concepts being blamed as the root cause of problems that they may not have been. 14 tooth pinions do not universally fail in 3 CIM gearboxes, for example, nor do plastic hubs.
If making a general rule and building very conservatively works for your team, that's great, just be sure not to give things out as general advice without a solid grasp of the "why".
Unread 11-01-2016, 11:23 AM
Data Nerd
FRC #0079
You're right, the intent of "inherently weaker" was "inherently too weak". They are weaker.
OccamzRazor's Avatar
OccamzRazor OccamzRazor is offline
Go YETI!
AKA: Robbie
FRC #3506 (YETI)
OccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to behold
Originally Posted by Bryce Clegg View Post
It probably was you guys, it seemed like your robot successfully scaled almost every single match. Your robot was an amazing one to watch and compete against. I remember that at Asheville we were playing defense against you, and your robot hit the ground very hard, at the point where most robots would break. Then, you guys fixed the robot and won the next match.
Gotta have a solid frame for a game like this and for antics like these:
https://www.youtube.com/watch?v=FEKWdsOhAdY
Yes, the other team was slightly terrified we were stuck in high gear at the wrong moment without bumpers and nearly landed on them.
They also learned to keep the battery strapped in a bit better since it disconnected and flew from the robot.
We did drop to the floor once from about 4 ft from the ground during testing but I can't remember any other serious drops on the field. Most of the climbing failures just resulted in a slow and uneventful descent. I was more worried about drive components cracking than frame this year.
2015 NC Regional Chairman's Award
2016 NC Guilford District Event Winner
2016 NC Guilford District Chairman's Award
2016 NC District Championship Winner
2016 NC Regional Chairman's Award
2016 NC Woodie Flowers Award Finalist - Lia Schwinghammer
