Go to Post A sign of character is the ability to move on and make the best of what you have, even if you feel you were completely wronged. - Cory [more]
Unread 03-11-2016, 10:55
TheMagicPenguin's Avatar
TheMagicPenguin TheMagicPenguin is offline
AKA: Josh B
FRC #1640 (Sab-BOT-Age)
TheMagicPenguin is an unknown quantity at this point
Re: [FTC]: Tetrix Motor cables
My advice would be to solder wires onto the terminals of the tetrix motor. Or you could upgrade to AndyMark Never Rest motors and the wires are built it.
I'm not scard to have the unpopular opinion.
Unread 03-11-2016, 11:00
Billfred's Avatar
Billfred Billfred is online now
This would be our advice here at AndyMark, and not just because we are the ones that sell NeveRest motors. (Most of us also lived through minibots, so we learned coping strategies. Nick has one magnetically attached to his desk.)
Unread 08-11-2016, 18:40
Tim Lankford Tim Lankford is offline
Tim Lankford is an unknown quantity at this point
You'll want to go with whichever strategy that works best for your robot design, be that going with custom wires and soldering directly to motor terminals, or moving to a different motor.
That being said, please know that if you've found bad motor cables in your new FTC set please contact support@pitsco.com or call 800-358-4983 for replacements at no charge.
Unread 10-11-2016, 11:32
Gilga Gilga is offline
FRC #2169
Gilga is an unknown quantity at this point
At our program I encourage all 9 of our teams to always use the andymark neverest motors for two reasons. One they come with the andymark power poles installed already which are directly compatible with the modern robotics modules. Two because they have built in encoders that work very well and are the easiest way to program a reliable autonomous.
We also switched from tamiya connectors on the batteries to Anderson power poles. If you have the funding, I highly recommend it. Just be careful to not accidentally invert the polarity or you will burn out your power distribution.
Motors and Wires:
http://www.andymark.com/NeveRest-s/550.htm
Unread 10-11-2016, 11:39
FRC #2169
Motors and Wires:
