Go to Post Is CAD essential to all teams? No, but neither are power tools. - 346CADmen [more]
Unread 03-11-2016, 10:22
Tsukunea's Avatar
Tsukunea Tsukunea is offline
Lead Designer, Drive Coach
AKA: Boone Shangle
FRC #6065 (Titanium Dragons)
Team Role: CAD
Rookie Year: 2016
Tsukunea is on a distinguished road
Calliope, anybody?
Hi, I'm not sure that this was the best forum to place this, but I suppose an admin can move it if necessary. Our team (6065) is looking at making a promotional robot for sporting events and things, and we are looking at putting a t-shirt gun on it. The idea just sprang upon me today that another fun thing to try might be adding a calliope to the robot to play our school fight song. Thoughts on the calliope?
B. Shangle
Lead Designer & Recruiter, Drive Coach of FRC Team 6065 "Titanium Dragons"
Kenowa Hills/Feyen Zylstra
Minister of Publications of Kenowa Hills Applied Technology & Design
"New Ideas for the World"
Unread 03-11-2016, 10:55
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Team Role: Student
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
Re: Calliope, anybody?
I'll admit I had to look up what a Calliope is, but certainly seems like an interesting idea. Looks like you'd have to actually, you know, generate steam somehow. This seems like it would be a messy thing to deal with, especially since you'd then be out of the range of FIRST legal parts, which means just about everyone you're dealing with is less experienced with such things. Assuming you got it electrically boiling, you'd also need a way of regulating the pressure evenly, otherwise bad things can happen. Also, you'd need to tune it. Either you'd get some pre made whistles, or you're going to spend a LOT of time getting the right pitch for each. From there you're either stuck in the key that your fight song is in, or you're making a chromatic one, which takes even longer.
I think the idea of it playing music is cool, but I'm not sure a acoustic instrument is the correct way of going about. Perhaps attach a speaker, a MIDI sequencer and a Animusic style light show (with less CGI)? I think that get's a bigger wow factor and is also easier on you, the people building the thing.
F4 Network Website Designer
2010-2012: A Whole Buncha FLL Teams; Team Spirit, Gracious Professionalism Award winner
2015-Current: FRC 1982, Captain, Electrical Lead
Beginning FIRST Volunteer
Moderator on the FIRSTwiki
Unread 03-11-2016, 11:09
roboruler roboruler is offline
roboruler is infamous around these partsroboruler is infamous around these parts
Combine the two build a Calliope T-shirt cannon
Unread 03-11-2016, 11:11
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We considered an (air rather than steam) calliope for our air cannon a few years ago, and decided that with the number of pipes and controls needed, it was much simpler to go the electronic route. We found a device online (sparkfun?) that was essentially an MP3 player controlled over a serial line. Put that into a car stereo amplifier, and add speakers.
Unread 03-11-2016, 11:17
ctt956 ctt956 is offline
Too many threads, too little time
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
I think a robot calliope sounds like an awesome idea! It would definitely fit the steampunk theme of 2017. You could use air to play it, but it would have to be a fairly basic calliope and play a short song, because as others have said, it could get pretty complex. You'll need a lot of air for it to work, but having a lot of tanks on the robot could pose a safety hazard. Maybe you could do it with fans?
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Use compressed air instead of steam as it will be much easier and safer to work with. Buy a heap of cheap pneumatic solenoids from aliexpress and a high flow 12v air compressor and some air tanks. Run the solenoids over a relay bank using an arduino mega. This will be the cheapest way of building what you want.
I think it will be a fun activity trying to tune all the different pipe lengths.
Unread 03-11-2016, 11:21
Originally Posted by ctt956 View Post
But having a lot of tanks on the robot could pose a safety hazard. Maybe you could do it with fans?
Explanation needed as to why a lot of tanks on a robot is dangerous/ unsafe.
Also fans will not work, because of the significant spool up and spool down time of the blades. A solenoid is off-on-off quickly a fan is not off-on-off quickly at all.
Unread 03-11-2016, 11:24
jaredhk's Avatar
jaredhk jaredhk is offline
Tried turning it off and on again?
AKA: Jared Hasen-Klein
FRC #1836 (The MilkenKnights)
jaredhk has much to be proud ofjaredhk has much to be proud ofjaredhk has much to be proud ofjaredhk has much to be proud ofjaredhk has much to be proud ofjaredhk has much to be proud ofjaredhk has much to be proud ofjaredhk has much to be proud ofjaredhk has much to be proud of
But...the calliope crashed to the ground.
Jared Hasen-Klein, Director of Team Operations
MilkenKnights.com | Facebook | Twitter | Instagram | Snapchat
FREE RESOURCES
Unread 03-11-2016, 11:50
Team Role: Student
Rookie Year: 2016
https://www.chiefdelphi.com/forums/s...&postcount=113
Unread 03-11-2016, 11:57
Ryan_Todd's Avatar
Ryan_Todd Ryan_Todd is offline
ye of little faith
Ryan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond repute
For COTS components/assemblies, here's one candidate supplier to consider:
http://ragtimewest.com/Catalog.pdf
If you're feeling spendy, they'd happily build the whole thing for you... otherwise, they'll fab and sell any percentage of the hardware that you're willing to pay for.
Unread 03-11-2016, 12:02
holazola holazola is offline
holazola is on a distinguished road
How about making something like this Barrel Organ? https://www.youtube.com/watch?v=rWz_X4nEzKk
Unread 03-11-2016, 12:19
Wow! that is quite a catalog! thanks for the link.
Looking at some of the related YouTube links to the one I posted above, there are several demonstration organs and street organs that could give you some good ideas. Even replacing the punch tape/ air valves with solenoids, you could still make a cool CIM powered bellows supply and your own pipes. Fun idea!
Unread 03-11-2016, 12:43
Tsukunea's Avatar
AKA: Boone Shangle
Team Role: CAD
Rookie Year: 2016
I have a feeling that we may have to use some kind of player-piano paper like that should we be unable to program the calliope for the song.
B. Shangle
Unread 03-11-2016, 13:02
Ari423's Avatar
Ari423 Ari423 is online now
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
No comment as to whether this would actually work, but if you want to avoid the problem of spin-up/spin-down time you could have a constantly spinning fan in a tube with the out-flow end covered so the air doesn't flow through the calliope. Then a small solenoid or something could open and close the cover to allow air through. Just an idea; still would be really complicated and a lot harder than a big set of speakers.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 03-11-2016, 21:46
Tsukunea's Avatar
AKA: Boone Shangle
Team Role: CAD
Rookie Year: 2016
I've found an old magazine from 1982 with instructions on building a mini-calliope. The air in it is produced by two hair dryers sans heating elements. It would seem that this would be a fairly easy route to go.
B. Shangle
