Go to Post I once started to build a time machine. But then I went back in time and told myself that it wouldn't work, so I gave up on it. -dave - dlavery [more]
Go Back   Chief Delphi > Competition > FRC Game Design
  #31   Spotlight this post!
Unread 02-11-2016, 19:41
Re: Worst possible game
You guys are all lightweights.
Starting point: 2001. (4vClock) For those that aren't aware of that game (Diabolical Dynamics), the basic idea was to stuff a bunch of playground balls in a couple of mobile goals, stick both mobile goals on a balance bridge, preferably with a large ball or two on top for extra points/multipliers, and stick your entire alliance in the far end of the field, as fast as possible (the faster you were, the higher your score multiplier).
Now, add 2 robots. (6vClock)
Change all the playground balls to Orbit balls, from Lunacy, and change the primary field surface to regolith (also from Lunacy--wheels too, folks!). Bridge gets HDPE surface (common in the '03-'06 timeframe).
And, just to make life totally miserable, the goals are the '02 goals (weighing in at 180 lb each)--AND bumpers are required, '10 bumper and extension rules.
Did I mention that the current field layout is used, and there's no communication between the field ends, but all the robots start at one end of the field?
Every time someone brings up Recycle Rush as bad, I have to remember that they probably haven't seen '01.
  #32   Spotlight this post!
Unread 02-11-2016, 21:06
ctt956 ctt956 is offline
Overanalyzing the Hints
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
Originally Posted by Poseidon5817 View Post
Trump Terror: Robots compete (on regolith of course) to build a wall across the middle of the field. Teams then launch foam balls over the wall into the other alliance's territory. If an alliance relaunches the balls back across the wall, bonus points are given.
Does that make you feel better?
Close, but what if each alliance had their own blocks for building the wall, and they must use the blocks belonging to the opposing alliance for the wall? Meaning there would be red blocks on the red side, and blue blocks on the blue side. The red alliance must take and use the blue blocks, and vice versa. Whoever finishes first wins, but any robots on the wrong side of the wall must be sent back to their side. If they refuse to go there on their own, they may be pushed, dragged, launched, or otherwise moved to the correct side. Additionally, one robot on each alliance will be assigned as Donald Trump, referred to as The Donald. The Donald will be identified by a wig and optional hat.
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
  #33   Spotlight this post!
Unread 02-11-2016, 21:53
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to behold
https://en.wikipedia.org/wiki/Diabolical_Dynamics
Specifically:
A few consider it one of the best FIRST games designed.
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
  #34   Spotlight this post!
Unread 02-11-2016, 21:58
Originally Posted by Hitchhiker 42 View Post
A few people probably also think Recycle Rush was the best FRC game to be designed. Ditto for Lunacy.
Just a thought.
(There's also the thought that perhaps someone needs to recall their English lessons from high school, particularly the slight yet significant difference between "a few" and "few".)
  #35   Spotlight this post!
Unread 02-11-2016, 23:13
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Specifically:
Let's put that quote in context:
Originally Posted by WikiPedia,Diabolical Dynamics, Reception
While most participants did not like the lack of "red versus blue" competition within matches, others praised the game for its inventiveness and emphasis on cooperation. A few consider it one of the best FIRST games designed.
There certainly appears to be a trend that all of the 4n+1 years (1993 Rug Rage, 1997 Toroid Terror, 2001 Diabolical Dynamics, 2005 Triple Play, 2009 Lunacy, 2013 Aerial Assist) have each introduced a distinct new challenge (or as I've called it before, a "bizarro" game), and most (if not all; I can't properly document the first two) seem to have been "love it or hate it" games. Unless the GDC is bucking this trend, this year we are living in "interesting times".
Edit: And OBTW, in 2013, there were at least two bizarro items. Not only were we required to launch frisbee discs with a robot that fit inside a 120" frame perimeter, the "hanging" postgame was regulated such that a "high" climb was mandated to be in no fewer than three separate stages. AFAIK, every other climb/hang game to date (both before and since 2013) could be completed in a single grab and pull.
  #36   Spotlight this post!
Unread 02-11-2016, 23:39
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
xkcd 285
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
  #37   Spotlight this post!
Unread 03-11-2016, 09:13
D.Allred's Avatar
D.Allred D.Allred is offline
FRC #4451 (Rat Rod Robotics)
D.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond repute
One adjustment. Your alliance wins if the other alliance builds the wall. Ready, set, play.
  #38   Spotlight this post!
Unread 03-11-2016, 21:08
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
Cellfone Folly! Break the phones out of phone jail to keep everyone in the arena alive!
  #39   Spotlight this post!
Unread 05-11-2016, 17:13
BrennanB's Avatar
BrennanB BrennanB is offline
TBC is good at getting almost first
AKA: Brennan Bibic
FRC #4476 (W.A.F.F.L.E.S.)
BrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond repute
Triple Balance on the 2012 bridge with 2009 wheels on the drivetrain.
Brennan Bibic - @b_bibic - Eh-Nalysis
10 years of inspiration compilation - W.A.F.F.L.E.S. #4476 YouTube Channel - 64 events and counting!
FRC 2013-2017 (W.A.F.F.L.E.S. Community Robotics #4476) - FLL 2006-2017 (W.A.F.F.L.E.S. #105) - VRC 2010-2013, 2015-2016 (W.A.F.F.L.E.S. #4476)
FRC 2009-2012 (K-Botics #2809)
Fantasy First 2014-2017 (The Breakfast Company) #TBCWin
2014 Dean's List Finalist
"Work until your idols become your rivals."
  #40   Spotlight this post!
Unread 05-11-2016, 20:28
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
And the bridge is regolith.
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
  #41   Spotlight this post!
Unread 05-11-2016, 21:17
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
You will also want to take some cues from FTC.
Make autonomous 30 seconds long and include various available tasks that are worth good points. Allow opponents to point their robot at yours and drive into you during autonomous.
Designate protected areas and field elements that your opponents can't touch. Put them in locations that both alliances need to drive near to play the game effectively. Make the field good and crowded so the protected areas aren't too easy to avoid. Give out huge penalties for bumping into them.
  #42   Spotlight this post!
Unread 07-11-2016, 01:08
Alsch Alsch is offline
Alsch is an unknown quantity at this point
Considering that both xkcd and sabotage have been brought up, I can't help but feel that https://xkcd.com/689/ is relevant somehow
  #43   Spotlight this post!
Unread 07-11-2016, 09:23
foote stepped in
AKA: E. Foote
FRC #0868
Just replay any year, cut the teleop period by 50% and extend the autonomous period by the same amount.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
  #44   Spotlight this post!
Unread 07-11-2016, 13:37
headlight headlight is offline
headlight is an unknown quantity at this point
Worst game I could come up with. Pretty long description, but in most of the worse games the devil is in the details.
Field is divided into a grid of 12 zones, 3 across, 4 down. Teams get points for each square they move into from their starting square as well as a multiplier bonus of how many zones away from their starting position they are at the end of the match. Teams may only block robots from entering a zone, they may not push opponents back into other zones, significant penalties are assessed for such an action.
The game objects are 1ft x 1ft memory foam cubes, there are 7 of them on the field, each robot starts with 1 and there is an extra 1 in the middle of the field. Points are awarded when a cube touches the ground inside a zone, per zone, cubes may not be dragged across the ground into a new zone, but must be lifted over the tape lines, if a cube touches the tape it negates the score of the cube. This score is divided by the number of zones away from their starting zone each cube is at the end of the match.
Robots may start in any zone they wish, one per zone. Priority is determined by a staggered load in order (red 1, blue 1, red 2, blue 2... etc).
Designated score keepers are expressly forbidden. There are two referees and the head referee. There is an automated laser grid system that matches the grid lines, but it does not record information, only feeds information about which grids it thinks are occupied based on entrance/exit information back to the referee display in real time.
The referee interface is divided into 3 screens, one screen for actions involving the robot (with alternating buttons for both scoring and penalties on a per robot basis), one screen for the actions of the cubes, tracked per cube, and one screen that is locked until the end of the match at which point the referees enter the starting and ending positions of all 6 robots and 7 cubes. Each referee must keep score and penalties for all 6 robots. When there is a discrepancy between the two referees, the average of the point values is taken per team.
  #45   Spotlight this post!
Unread 07-11-2016, 18:56
Zebra_Fact_Man's Avatar
Zebra_Fact_Man Zebra_Fact_Man is offline
]\/[ Go Blue!
AKA: Solomon
FRC #1076 (Pi Hi Samurai)
Zebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant future
Originally Posted by frcguy View Post
Aerial Assist on regolith (with Lunacy wheels)?
Alternatively, Aerial Assist where high-speed ramming is legal and you receive some kind of point bonus for it.
Are you mad?!? That sounds awesome!
Oddly enough, DD was my high school team's Head Coach's favorite game.
One of my design mentor's favorite game so far is RR.
Also, one of my favorite games is Lunacy.
I guess we're just one odd group of mentors.
My Journey in FIRST:
Mentor/Coach/Engineer
2014-2017: Team 1076 - Pi Hi Samurai
____ 2014: Team 5220 - The Rockets
2009-2014: Team 313 - The Bionic Union/Bionic Zebras
Student
2006-2009: Team 313 - The Bionic Union
