Go to Post We’ve been chasing perfection since 2003 in the hopes of catching excellence. - Karthik [more]
Unread 06-11-2016, 12:58
cnc4 cnc4 is offline
FRC #2231
cnc4 is an unknown quantity at this point
Getting axisCamera image result in an exception somtimes
Hi all, my team and I are trying to make vision code for the robot.
The vision works great but sometimes we get an exception from the getImage method in the axisCamera class. After I get several exception I get an outOfMemory exception pointing on the getImage method. Those two exception are pointing on the native method that the getImage use.
Error:
_Priv_ReadJPEGString_C(image.getAddress(), getByteBufferAddress(string_buf), stringLength);
Line 29329 in NIVision.class.
I dont have the error text right now but this is an unkownError type. the error code is imaqError -123673104, I didnt find any help in the internet for this error.
Thanks in advance!
Unread 07-11-2016, 07:20
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Getting axisCamera image result in n ecxeption somtimes
That error code is undocumented. Can you post the full error text?
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 07-11-2016, 08:21
FRC #2231
Here you go, hope this help.
Thanks for your help!
Name:	vesion error.png
Unread 07-11-2016, 11:09
euhlmann's Avatar
CTO, Programmer
AKA: Erik Uhlmann
Rookie Year: 2015
Take screenshots please
So it's more than an undocumented error code, it seems WPILib is actually using NIVision black magic with a "private" function that's completely undocumented. You might be better off opening an issue on the WPILib repo. I can't help without documentation or source code
Unread 07-11-2016, 23:00
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: Getting axisCamera image result in an exception somtimes
Error:
Thanks in advance!
My understanding of the NIVision code is that it's actually written in C++ natively and have a Java wrapper. Because of this, the Java garbage collector doesn't reclaim image buffers allocated by NIVision API. Therefore, if you allocate image buffer for every frame, you are going to run out of memory really fast if you don't explicitly release the buffer after it's done. There are a lot of discussion threads about this issue, you can probably find and read them in the forums here. There are two ways to fix this. You can either rewrite the code so it doesn't allocate a new image buffer on every frame you process (we rewrote our code that only uses two preallocated frame buffers), or you will need to call image.free() when you are done with the buffer (Please note that I don't have the NIVision documentation in front of me so the actual API name may be different).
Unread 07-11-2016, 23:32
FRC #2231
But the main issue is that I get an unkown exception. You thinks that the exception is cused by outOfBufferException in the native method?
I would of take screenshots but I did't had the computer neer me .
Ammm... so it never happend to other teams? No one ever reported this issue?
