#16
Re: pic: Ultimate chain tool project
The idea of the current design is that it would have a channel for the old pin to be loaded into, such that the pin would automatically be aligned by the tool. Are you saying that this design would not work as intended, or would not be an improvement? I guess I'm not sure why people think pressing the pin part way out is a better solution, when it requires a certain width of chain, and that the pin does not accidentally fall out. |
#17
Not saying this wouldn't work, though. Maybe you can machine a matching block that slips into the pocket with the relief / hardstop set for the right distance to allow this? That way you have a tool that can do both partial and full removal. |
#18
As it is a press fit, even under perfect alignment, it is having to generate some force before it slips back into the hole. That force can force things out of alignment if everything is not perfectly restrained. Perfect restraint can lead to some tolerance stack-up issues in an actual part/tool. It is my opinion that leaving the pin in the outer link is the simpler solution, but I'm also interested to see you try it your way and validate/invalidate our observations. |
#19
Is the pin supposed to go where the mandrel is after it's been fully pushed out in order to push it in? That makes this a lot easier. As in, push the pin up the hole the mandrel pokes out of, put the chain pieces to be attached on the guides, then press back in? Quote:
#20
That is the idea. The threads chosen also have a minor diameter that is almost exactly the diameter of the chain pins being pressed, so there should be nowhere for the pin to go except into the chain links. |
#22
Back to the OP though, really just encourage you to make some chips and let us know. Making a chain breaker is on my list somewhere behind too many other projects, but it's on the top third of the list for sure. If you can come out with something that works, I'm sure there will be a few interested people. |
#23
any chance of getting the cad files for theses?
#25
Do you prefer inventor or STEP?
#26
To be honest I am not sure. I'd have to check with my machinist, but I think step will work.
#27
Regarding the "push the pin out" and the Dark Soul tool: My experience is that once you use a Dark Soul tool to break heavy duty #25 chain (e.g. Vex), you will not be able to use it conveniently on regular duty chain again, because the pin will be pushed out before you hit a stop. For precisely this reason, we have two dark soul tools, one tagged "HD only" and the other "RD only". We keep the HD chain in one bin, the RD chain in another bin, and the tools in their respective bins. So far, the "RD" tool is still in usable shape. If the tool gets messed up, I suspect that we shall simply toss all of our RD chain; it'll be less expensive than getting another tool every year or so.
