Go to Post The toughest regional is always the one you are competing in! - AcesPease [more]
Unread 07-11-2016, 13:51
Owen Busler's Avatar
Owen Busler Owen Busler is offline
Build Captain
FRC #0303 (Test Team)
Owen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant future
pic: Team 303 Spider Robot
Unread 07-11-2016, 13:52
LiterallyMatty LiterallyMatty is offline
AKA: Matthew McMahon
FRC #3397 (Robolions)
LiterallyMatty can only hope to improve
Re: pic: Team 303 Spider Robot
This is the only time it is acceptable to receive candy from a white van.
Unread 07-11-2016, 14:11
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
I'm interested to see how the pneumatics will stand up to hours of continuous usage. Unless you specifically bought a compressor with a 100% duty cycle, many of the common compressors used in FIRST will only work at 10% of max efficiency after 10 minutes of continuous usage. When we bring robots to community events, we always try to bring ones without pneumatics. Otherwise, we have to give the robot frequent pneumatic cool-down breaks and even then we still sometimes melt the plastic tubing.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 07-11-2016, 16:32
Build Captain
This is the compressor we used:
http://team358.org/files/pneumatic/4...on25875-03.pdf
(Thanks 358 for the spec sheet)
We have run this at multiple demos at around a 30% duty cycle for 2-4 hours with no problems. In the end it gets a little toasty, but its been working for a good 20 demos now in addition to being used many years ago on one of our competition bots.
2016: Deans List Semi-Finalist/MAR Mount Olive District Engineering Inspiration Award/Buckeye Regional Second Alliance Captain/MAR Montgomery District Event Imagery Award/MAR Championship Gracious Professionalism Award
2015: MAR Mount Olive District Chairman's Award/MAR North Brunswick District Winners/MAR Championship Finalists
2014: MAR Clifton District Chairman's Award/MAR Championship Regional Chairman's Award
Unread 07-11-2016, 17:53
Ari423's Avatar
FRC #5987 (Galaxia)
How do you manage a 30% duty cycle at a demo?!? We usually run at almost 100%. Granted that is a pretty small cylinder but I imagine you are firing it pretty frequently.
2013: Programmer
Unread 07-11-2016, 18:47
Build Captain
That was a pretty rough estimate. We have 4 air tanks on the bot and we do some driving and disable-ing to allow the community to take a closer look at the bot. Between that and down time for batteries id say 30-40 percent is pretty accurate.
