Go to Post Any FIRST pit is my favorite because that means I'm enjoying a FIRST competition so I'm just plain happy anyways. - Koko Ed [more]
Unread 08-11-2016, 01:17
TacoTheCat TacoTheCat is offline
AKA: Katya Rott
FRC #2374 (Crusader Bots)
TacoTheCat is an unknown quantity at this point
Re: What hath we wrought? 2016 Horror Stories
Originally Posted by codedr View Post
I learned that if the battery cables can be rocked back and forth at the battery or at breaker, they are too loose and will cause high current draws that shutdown the robot.
Wow, we had the same problem over here, except it didn't pop up until after the season. We discovered that if the robot dropped hard enough, it would shut down. After a little bit of percussive maintenance (aka we pushed the wire back and forth for a while) we found that if you move the main power cables around enough, the robot shuts down.
I wonder if there is a good fix for this? Securing down cables a certain way, or creating more secure connections between them?
