Go to Post Can't engineers be jesters? - danielkitchener [more]
Unread 08-11-2016, 13:15
Data Nerd
FRC #0079
Re: Drop Center Distance
Originally Posted by Chris is me View Post
Drop centers are a function of a few variables
1. Wheelbase length and width
2. Wheel material (rubber, tread, pneumatic, tracked)
Good rules of thumb:
Pneumatic wheel - 1/4"-3/8"
Treaded wheel - 1/8"
Rubber wheel - 3/32"
Your mileage may vary. Keep in mind all of the "conventional wisdom" for drop centers was determined when wheelbases were usually 38x28, or much longer than they are wide. Drive bases closer to square shapes may need less drop, and wide bases may need no drop at all. But a little too much on a 6WD isn't the end of the world.
This year 228 did 1/8" drop on a 10WD, with the outer wheels raised up 1". This was unnecessary, we didn't need any drop at all with how short our effective wheelbase was.
Not mentioned but also important:
Surface you're on. Carpet is gonna be different than HDPE is different than metal mesh.
Stiffness of chassis. A wet noodle of a chassis won't matter how much drop you have.
Unread 08-11-2016, 13:46
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
8 wheels, 8" (actually 200mm) pneumatic.
center wheels were dropped 0.5" (alternately, end wheels were raised 0.5"....)
with a center distance of 8.75" between wheels.
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
