Go to Post Maybe this thread should be re-titled "Waiting impatiently for the 2011 hint!" since having over 100 posts doesn't seem very patient. - Joe Ross [more]
Unread 08-11-2016, 13:49
rtse's Avatar
rtse rtse is offline
449 Lead Programmer
AKA: Ryan Tse
FRC #0449 (Blair Robot Project)
Rookie Year: 2016
rtse is an unknown quantity at this point
Suicide Cables Safe for Motors?
My team decided to ban suicide cables for connecting motors directly to batteries for safety reasons and to extend motor lifespan. Our electronics team is building a regulator with a potentiometer and a fuse to go between batteries and motors so that we can test without a RoboRIO and/or speed controller.
I have seen many teams use suicide cables to spin motors at competitions, and as far as I can tell, connecting motors directly to batteries seems to be the norm.
What is the purpose of such a regulator?
It seems to me that supplying a 12V motor with 12-13V from FRC batteries shouldn't cause the kind of physical motor problems due to excess voltage that I read about (saturation).
Can FIRST motors really draw enough current from FIRST batteries to cook themselves? Or is there another problem that I am missing?
Disclaimer: I am a clueless software guy and I don't know much about this stuff. I just want to understand the science behind why my team is doing this.
Ryan Tse
2015-2016: 449 Programmer
2016-2017: 449 Lead Programmer
GitHub
rytse@mbhs.edu
Unread 08-11-2016, 13:54
snekiam snekiam is offline
FRC #3322 (Eagle Imperium)
snekiam has a spectacular aura aboutsnekiam has a spectacular aura aboutsnekiam has a spectacular aura about
Re: Suicide Cables Safe for Motors?
Our team has been controlling motors for prototyping with suicide cables for awhile now - I haven't noticed many motors die when they are not stalled - that is where the problem could occur, and you could release magic smoke. But a regulator like you are describing could be useful for speed control - a la thrifty throttle plus pwm motor controller. This can help when prototyping a shooter, where speeds may be very specific.
Unread 08-11-2016, 13:57
MechEng83's Avatar
MechEng83 MechEng83 is online now
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
We have something we call our "motor tester" which uses an old speed controller hooked up to a chip that generates a pwm signal with a potentiometer to adjust forward or backwards at differing voltages. The main power to the motor controller is provided by a regular robot battery which we have hooked through one of the normal 120A breakers and another bus unit (I think from 2009 or earlier) with one of the 40A breakers used on the PDP.
I'm a hardware guy, so I can't really provide more details on this, but it seems like not the greatest idea, safety wise, to use direct voltage on the motor. I'm not sure there's much of a problem from the motor's perspective.
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
Unread 08-11-2016, 13:59
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Yes, FRC motors can cook themselves, under some circumstances. Mostly, when they stall (don't move) while being powered. With some motors, this can even happen on the robot before the breaker trips.
It's all a question of heat dissipation. Moving that much current through a motor will cause it to generate heat. Some motors, like the CIM motors, have significant thermal mass, and can absorb a lot of heat - stalling them out for short periods is usually ok, which is why they're almost always used on the drive train. Other motors, like your typical 500 or 700 series (Banebots 550, 775, for example) don't have that thermal mass. Instead, they rely on built in fans to draw air through the case to dissipate the heat. Those fans only move when the motor is moving, so when you hit a stall condition and are still generating heat, there's no where for it to go... it builds up quickly and poof, your motor is dead.
Make sure whatever potentiometer you're using is rated to carry significant current- most of them aren't! A better (and much easier) solution is to get an old drill. Take it apart, remove the motor and hook up an Anderson connector on one end and whatever standard connector you use on your motors on the other. You can also stick a breaker in the middle somewhere. Then you can easily plug in a motor, control it's speed dynamically, and even switch between forward and reverse! Plus, the internals are going to be able to handle the current in a vast majority of cases.
2016: Lake Superior WFFA
Unread 08-11-2016, 14:03
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
To answer your most pertinent question: Yes, FRC motors when stalled can draw dangerous amounts of current. The stall current on a full size CIM is about 130A. While there is a risk you would damage the motor internally, there's also a risk that you'll cause a fire hazard by overheating the wires.
The safest way to test motors is to use something similar to what MechEng83 suggests: have a main breaker to protect the battery, 6 AWG connections between the beaker, battery, and power distribution board, and a 40A (or other suitably sized breaker) to protect the motor wiring. Fuses and breakers protect the wiring, which is what typically presents the largest safety hazard.
As an aside, if your team uses a potentiometer as you mention, that's going to have to be one big potentiometer. Certainly not the sizes that would be used for sensing or what you would find at radio shack. Even under nominal loads, like a CIM motor in a drivetrain on carpet, motors will draw >10A with much higher peak currents when starting. Bear in mind the power rating of your potentiometer when selecting it.
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
Unread 08-11-2016, 15:01
ctt956 ctt956 is offline
Overanalyzing the Hints
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
I think safety is the biggest issue with suicide cables. As others have said, a stalled motor could draw dangerously high current. Depending on how to cables are connected, a wire short hazard may also exist due to how easily the exposed wires could contact each other. Having a breaker would not only protect the circuit, but also allow you to turn it off quickly and easily should you need to do so. As for the potentiometer, definitely make sure it can handle the current you intend to run through it. I once put a small potentiometer in a circuit with a smallish 12V fan as an attempt at speed control. The device that originally had this pot ran on 12 volts DC, so it seemed like it could work. There was nothing else on the circuit. I might have connected something incorrectly, because I don't think the fan worked, but there was some magic smoke from the potentiometer.
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 08-11-2016, 17:17
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
I'm not sure how all these teams are stalling their motors in prototyping. 115 has used direct battery-motor connection cables via Powerpole connectors for years without issues, to test shooters and other mechanisms. Having a speed controller like the Thrifty Throttle would make it easier to test different speeds, however.
As far as competition goes I haven't seen a team every connect motor to power without a speed controller in between. That seems like a recipe for disaster.
Unread 08-11-2016, 17:33
rtse's Avatar
449 Lead Programmer
AKA: Ryan Tse
Rookie Year: 2016
I meant testing motors on broken mechanisms in the pit. Sorry for being unclear.
Ryan Tse
GitHub
rytse@mbhs.edu
Unread 08-11-2016, 18:12
Seth Mallory Seth Mallory is offline
FRC #0192 (GRT)
Seth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond repute
GRT takes the motors of 12 volt drills and install leads with Anderson connectors. You can add a fuse to both leads. This gives you a variable voltage reversible polarity power source. We we test motors and mechanisms with this. We have Y cables and can run one side of our drive train with them. One of the advantages of this design is if a mechanism is binding it will not break due to the low power output.
KF6UZX
Unread 08-11-2016, 20:06
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
For 99.9% of mechanisms/people I would say this would be safe for the motor, although not necessarily safe for the people around it.
Unread 08-11-2016, 20:57
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We have done this, though always where we were confident that something would slip before things would break or blue smoke would be released. We actually used something like this on our air cannon for a game early this football season, but we did have circuit breakers (a "Stinger" 4 circuit MAXI fuse block) and switched the motors with pushbutton automotive starter switches (which are difficult enough to operate that they serve as a built-in dead man switch). As light as our air cannon is this year, it would require a gifted act of sabotage or multiple failure modes worthy of Wiley Coyote or the stooges to stall our drive motors. Whether the switches would smoke or the breakers would trip first is probably a valid question.
Edit (addition):
Sure, all the time. Spike relay modules to switch automotive & PG motors on and off.
Unread 08-11-2016, 22:18
Joey1939's Avatar
Joey1939 Joey1939 is offline
AKA: Joey Holliday
FRC #1939 (Kuhnigits)
Joey1939 has a spectacular aura aboutJoey1939 has a spectacular aura aboutJoey1939 has a spectacular aura about
My team made a video a few years ago on how to make one of these. https://youtu.be/3q4nHCzSer0
Unread 08-11-2016, 22:30
FRC #0192 (GRT)
Nice video. We have been making then for close to 20 years know. We use the batteries that come with the 12 volt drills. This makes them potrable and low powered. This reduces the chance burning the controls in the drill housing. It also may not matter and we just keep doing the same way.
The drill motors are great for projects. We use them off many off season projects. We add anderson connectors and you can guess the powersource.
KF6UZX
Unread 09-11-2016, 08:44
EmileH's Avatar
EmileH EmileH is online now
it's not a water game, ok?
AKA: Emile Hamwey
FRC #1058 (PVC Pirates) & SLFF (NE Way You Want It)
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
Can confirm this. During one of 3467's 2015 practice sessions, we stopped mid-match before we were about to place a six stack + can and noodle while leaving the robot enabled. It turned out that our software was still holding a position slightly above ground level, hence stalling our two-miniCIM elevator for more than two minutes. It did not trip the PDP breakers. After that, those two miniCIMs were cooked for good (also the shop smelled considerably of burning CIM internals ).
2016-present: High School Student, FRC 1058 PVC Pirates
2016: RiverRage 20 Champions, Battle of the Bay 3 Champions
2013-2015: Middle School Student, FRC 3467 Windham Windup
Unread 09-11-2016, 11:59
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
The breakers used in FRC don't really protect the motors. They self reset very quickly letting current through. If you were using 40 amp breakers with the mini cims, it is possible to stall the motor with current sufficient to fry the motor but less than what it takes to trip the breaker.
