#16
Re: Advantages/Disadvantages of West Coast Drive
BEFORE the WCD was developed (2002-2004 timeframe), of course, but seeing as 254 is one of the developers of the WCD... The WCD was officially unleashed in late 2003/2004 season, the result of a collaboration between 254 and 60. There are photos in CD-Media from 2001 showing both teams running elements of what is now known as a WCD, though 254 for some reason ran their chains outside their frame from a central gearbox that year (either one of which would, under the traditional definition, disqualify the drive as being WCD), and neither had more than 4 wheels on the ground (also disqualifying as a WCD under the traditional definition, which requires 6 (or more, depending just how traditional you want to get)). So, more detailed answer: yes, but it's been quite a while and they were developing WCD when they did. And now back to your regularly-scheduled discussion of the pros and cons of the WCD. |
#17
We are a low resource team, like really low resource, yet we do WCD with success. Last edited by dirtbikerxz : 09-11-2016 at 09:33. |
#19
I'd disagree with that argument since it's not a function of raw number of resources but more a function of what type of resources and the allocation of them. For teams with tight budgets and resources using the KoP or VP DIAD may be better uses of tight resources. I don't see how 254-copy describes advantages or disadvantages for the purposes of resource allocation. |
#21
For me, it's either WCD or KOP. Either can be purchased and put together with nominal amounts of machining and programming work.
Presuming you use all-COTS for either drive train, these are IMO, of course:
#22
I find this discussion interesting from the standpoint of the definition of WCD, KOP, & traditional when related to past baseline definitions. They seem to vary with how long you have been around. These definitions are very fluid and I believe will continue to be so. Just a thought.
#23
![]() Example of said WCP gearbox with integrated sprockets and bearing block. If we go WCD next year, we'll probably be using these. Last edited by frcguy : 09-11-2016 at 15:01. |
#25
And before I even thought about working at AndyMark, we made a Toughbox Mini work for a chain-in-tube-with-coulda-been-cantilevered-wheels (but weren't cantilevered because this game is brutal) by getting the flat front plate, using the long output shaft cut to length, and pressing a bearing into the tube. Done.
#26
AM - practically non-existent because the mount points interfere with the chain runs WCP - yes! We've used these for 2 years now and love both the single and double-speed options. WCP-WCD-DS lasted through 85 matches in 2016 during the preseason, competition season and post-season with zero issues. Zero. None. We snapped quite a bit of chain (broken links), but the gearbox kept on chugging. VEXPro - Single Speed: The single-speed double-reduction looks like it will work for WCD as-is, yet I have some reservations about longevity. There are effectively about 5.5 lbs cantilevered off of 2 mount points through plastic housing. I'd trust such a setup for a single competition. Yet I have reservations for so many matches between March 1 and November 31 in a game like 2016 (with considerations for transporting the robot so many times). It would require additional support somewhere, either from adapter plates or a super structure. So IMO it's not quite plug-and-play in WCD. My team could easily get it done, but I'm not sure for a typical team. There also seemed to be a very large sensitivity to assembly tolerances on the VP Ball Shifter. I heard of multiple teams who had gear teeth sheer on the 3rd stage due to slight misalignments, and one such team was our alliance partner in the Finals at their 2nd event. It was something manageable, but I know my team would have to consider how rough the game is on drive trains before purchasing ball shifters. These are, of course, my perspective based upon what I know about my teams strengths and weaknesses. |
#28
Yes. I wouldn't want to use it every year, but it might have been worth it to play Stronghold with a drive train that works almost as well even if you lose a chain. We could have spared the extra few pounds this year. Last edited by GeeTwo : 11-11-2016 at 10:20. |
#30
