Go to Post I'm unconvinced that this thread itself is not a performance art piece. - DCA Fan [more]
Unread 09-11-2016, 09:51
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Advantages/Disadvantages of West Coast Drive
For me, it's either WCD or KOP. Either can be purchased and put together with nominal amounts of machining and programming work.
Presuming you use all-COTS for either drive train, these are IMO, of course:
  • WCD is easier to customize around an overall robot design since the frame consists of only 5-6 basic parts.
  • WCD maximizes robot stability by putting the wheels at the outer-most maximum dimensions
  • WCD makes it far easier to experiment with and find the right wheels - and then maintain them throughout the season
  • WCD makes dealing with chains super-easy. If a chain snaps (literally) because of a wonky new offseason defense (@Nate @Matt .... ) then a fix requires just a few parts of adjustment rather than removal of anything.
  • WCD reduces flexibility when it comes to bumpers. There are ways to design bumper mounts to make them secure, and most of them over-complicate the frame design when compared to the simplicity of WCD itself.
  • WCD can be done with rivets, but IMO it is far simpler to design and execute if a team has a welding sponsor. The middle cross rail usually drives me up the wall, unless we have a welding sponsor.
  • If welded, WCD frames are less forgiving if not properly cooled. The reliability of chains presumes the side rails are perfectly straight.
  • WCD setups have very few COTS "plug-and-play" options that are designed specifically for WCD. Most gearboxes used in FRC will require some sort of custom mount in order to direct-drive one of the wheels in WCD. This isn't an insurmountable issue to fix for an individual team. Yet don't expect to go to the 3 major FRC gearbox suppliers to find anything that adapts non-WCD gearboxes to a WCD setup.
GitHub
