Go to Post I would proudly put an AndyMark sticker on our robot any day! - Andy Grady [more]
Unread 10-11-2016, 01:46
soundfx's Avatar
soundfx soundfx is offline
AKA: Aaron J
FRC #3238 (Cyborg Ferrets)
soundfx is an unknown quantity at this point
No space left on device error
My team is attempting to deploy code to a roboRio traditionally used for testing purposes in the past (successfully), yet after no known changes to the device (besides our numerous attempts at updating firmware, reimaging, and reinstalling java), we get an error that says:
java.io.IOException: No space left on device
    at java.io.FIleOutputStream.writeBytes(Native Method)
    at java.io.FileOutputStream.write(FileOutputStream.java:307)
    at edu.wpi.first.wpilibj.hal.JNIWrapper.<clinit>(JNIWrapper.java:40)
    at edu.wpi.first.wpilibj.RobotBase.initializeHardwareConfiguration(RobotBase.java:170)
    at edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:182)
Despite what the error states, the driver station claims that there are 228 MB of disk space left on the roboRio. We have tried this with identical results from multiple computers, both which claim the build was successful upon deploy. It's the same story whether we use last year's robot code, an empty brand new project, or code we just wrote. RobotInit doesn't even start running, and no error output is produced through the network. This message was only discovered after using ssh to manually start the robot code. We have not yet been able to test on another roboRio.
Any ideas? Help would be greatly appreciated.
"I got 99 problems but 0.999 ain't 1."
~Orteil
Unread 10-11-2016, 06:42
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: No space left on device error
You could try re-imaging the rio
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 10-11-2016, 10:24
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
Team 3991: Driver since freshman (2015-), Captain since sophomore (2016-), CADer
"The human condition is not perfect. We are not perfect specimens, any of us. We're not robots." - Michael Ovitz
My posts may or may not reflect the views of my team, they are my opinions, and mine alone.
Unread 10-11-2016, 10:34
bdaroz's Avatar
bdaroz bdaroz is offline
Programming Mentor
AKA: Brian Rozmierski
FRC #5881 (TVHS Dragons)
Rookie Year: 2016
bdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud of
Have you tried SSH'ing into the RoboRIO directly and checking the free space on the device? Is there a chance your code is flooding logs at a very high rate?
Unread 10-11-2016, 10:46
euhlmann's Avatar
CTO, Programmer
AKA: Erik Uhlmann
Rookie Year: 2015
Originally Posted by dirtbikerxz View Post
Whoops, looks like I didn't read the post.
Unread 10-11-2016, 11:02
If you connect and use the web browser to view the robot's config page, it will also show you the disk and memory and CPU usage. Please use that to verify the disk free number.
And of course you could check from a shell. If you truly have 100s of MB, you will need to work with the Eclipse folks to determine what the error truly means.
Greg McKaskle
Unread 10-11-2016, 12:03
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
I have experienced this error for this reason:
When the code starts, it extracts the WPILib JNI library to a tmpfs partition (/var/volatile, I believe). If the code crashes in native code, either the JNI library temp file won't be deleted or a coredump is written to the same temp directory, or both (I can't remember). The code restarts over and over eventually filling up the temp directory and causing this error.
I'm not sure why your code would be crashing like this, but I would recommend checking to see if /var/volatile is being filled. If so, kill the script that automatically restarts the code, then empty /var/volatile, manually start the code and view the FRC_UserProgram.log file. I have seen some cases where errors are not printed to the driver station, but are printed to the log file.
Let me know if you have any questions.
Unread 11-11-2016, 00:27
soundfx's Avatar
AKA: Aaron J
Turns out the code was lacking the initialization of an array of Talons, which oddly enough wasn't being caught by the compiler or IDE. Another strange thing was that we were able to run any working code on the roboRio before we ran the broken project, but after that project was ran, all code attempted to be ran would not work.
Thanks for all your help!
~Orteil
