Go to Post Brandon, it's not an issue... but the fortune cookie thing that you get when you give someone rep is a little creepy... - Beth Sweet [more]
Unread 10-11-2016, 15:25
Ubspy Ubspy is offline
FRC #2335
Ubspy is an unknown quantity at this point
Reading encoder values?
I'm having trouble reading values from the coders. When it goes forward I get increasing values for the .get() function (for the encoder). But when I reverse the motor everything the values stay the same, and when I go forward again they continue rising, and they all stay at 0 (I'm printing the get(), getRaw(), getDistance(), and getRate() values).
I don't know if it's wiring or coding, but my code only calls reset on the initialization of the subsystem (we're using java command based programming), so I don't know why it would be resetting.
For the wiring, I only have power going from one digital input, but I'm using 2 DIO ports for the signals.
Any ideas on how to reduce the get() when going in reverse?
Unread 10-11-2016, 16:26
Logan Byers Logan Byers is offline
Roaming Mentor & Referee
no team (Team Indiana)
Logan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud of
Re: Reading encoder values?
Definitely sounds like a wiring issue. Double check the signal wires for the encoder and the connection to the encoder itself.
Troubleshooting tip: switch the channels of the encoder. Does the encoder reading flip? If so, you may have a bad encoder. If it stays the same after switching the channels, you may have a bad DIO on the RoboRIO.
Unread 10-11-2016, 17:04
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We had a (homemade) encoder disk our rookie year which would only rotate one way; something caught it when going the other way.
Unread 13-11-2016, 19:33
FRC #2335
If we use DIO ports 0 and 1 it works fine, but DIO ports 2 and 3 don't seem to work as well.
