Go to Post Just a note, there are 2,534 teams registered and competing in FRC this year. That means that there are 2,533 teams being run in a manner entirely different than your own. - Jay Trzaskos [more]
Unread 11-11-2016, 07:06 AM
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
Custom Gearbox is very loud
So we just build our first ever custom gearbox, and it's one of the "opened" once. As in, you can see the gears and all, and when testing it we feel like it's very very loud compared to anything wev'e had before.
Now, all our previous gearboxes were enclosed once, like the ballshifter for example.
So what we want to know, if that loud noise is just how it is supposed to sound like with an opened gearbox, or is that means that something's wrong.
Thanks!
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 11-11-2016, 08:06 AM
Levi Madden's Avatar
Levi Madden Levi Madden is online now
Student
FRC #1987
Levi Madden is an unknown quantity at this point
Re: Custom Gearbox is very loud
Part of the reason it is louder is because of the exposed gears, but I'm guessing it's not the whole reason. Have you put any kind of lubrication or grease on the gears? That usually helps. Also make sure your gears are not binding up, if they are meshed too closely together, they tend to bind up/be loud.
Unread 11-11-2016, 08:10 AM
page2067's Avatar
page2067 page2067 is offline
AKA: rick page
FRC #2067 (Apple Pi)
page2067 has a spectacular aura aboutpage2067 has a spectacular aura aboutpage2067 has a spectacular aura about
No it shouldn't be that loud.
We have built several custom open gearboxes times in the past few years - One time it was being put together - it seemed a little hard but the students persevered - and then it screamed when first run! - well it was put together with 14 tooth pinions where the gear centers were set up for 12 tooth pinions - once fixed - it purred.
We also find that if using 2 parallel plates with spacers for the gearbox that before you tighten the bolts through the spacers, feel how the gears turn, get them right before socking it down. Ideally we want to control the center distances by a couple thousandths or so - but there is typically more slop in the bolting up process - things you can get away with in FIRST.
If it is too loud - screeching - then I would guess the center distance between the gears you are using is too tight, If too loose, it will not be as loud - just lots of backlash, and premature wear.
Unread 11-11-2016, 08:31 AM
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
If you have a tacometer, measure output speed vs theoretical output speed. This can help estimate how much drag you have. If you are at 75% or lower free speed, you definitely have something too tight. If the gearbox turns very free, and free speed is high say 97% then you may have gear centers too far apart. There will also be a lot of lash compared to other gear boxes.
Unread 11-11-2016, 09:05 AM
Tottanka's Avatar
AKA: Liron Gurvitz
We are using the 12 pinion once, and we did grease the whole thing.
The plates were made in our CNC machine, and the CAD was done according to pitch diameters of each gear. The loud noise seems to come from the gear that attaches to the CIM pinions (2 motors go to one VEX 72 teeth gear).
We would like to avoid fabricating the whole thing again, any suggestions? How much should we separate the gears beyond the tangent distances of the 2 gears?
Unread 11-11-2016, 09:46 AM
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We had a different set up, but it sounds analogous. We were able to quiet a TB-mini simply by removing a CIM, turning it 180 degrees around its axis, and re-mounting. Shouldn't make a difference, but it did. I would try mounting each motor separately and in both orientations to see where the binding is occurring. If you have binding all over, you may need to increase the spacing.
Edit: this happened to us twice with different gearboxes and plates in different years. I can't prove it was the same CIM in both cases, but I wouldn't be a bit surprised if they were.
Unread 11-11-2016, 09:48 AM
Billfred's Avatar
Billfred Billfred is offline
Was it the exact pitch diameter sum, or did you add something to it? What is the actual center-to-center distance on the plate, as machined?
For drive in FRC applications (short runtime, friction bad), it's conventional wisdom to add about .003" to soak up manufacturing variations and go a little loose and free.
Unread 11-11-2016, 09:56 AM
Tottanka's Avatar
AKA: Liron Gurvitz
We used the exact pitch diameters.
We will try checking each motor separately on Sunday, and than if that doesnt work we'll probably remake the plates.
I'll keep the results posted here.
Thanks everyone!
Unread 11-11-2016, 10:07 AM
Chris is me's Avatar
AKA: Pinecone
Thanks everyone!
If you didn't add the center distance, and you're using aluminum gears, one trick is to run the gearbox on a bench for about an hour or so, ungreased, changing direction frequently. This will wear down the parts somewhat, to sort of "break in" the gears. Once this is done, clean the gearbox out thoroughly, heavily grease it, and you're good to go.
The .003 center adder trick is a way around doing this, at the cost of a bit more backlash in your system.
Unread 11-11-2016, 11:28 AM
Tottanka's Avatar
AKA: Liron Gurvitz
Have you done this before? The 1 hour of running part i mean. It sounds like the wear might be too much. What speeds would you run the gear at for that?
Thanks!
Unread 11-11-2016, 11:57 AM
AKA: Pinecone
Thanks!
I haven't personally done this in a long time, I should have specified. I've heard of it done before from a few friends who swear by it, and the times I have done these things have been with gearboxes with center distance added already and it didn't change much.
The wear is to some extent controlled by the system not being under load. This would be on a bench, with maybe a wheel or something on the output shaft just for a smidge more inertia.
Unread 11-11-2016, 12:07 PM
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Thanks!
Yes, high speed, no load. We have used a "suicide cable" for this, so we were running at free speed. With the amount of resistance it sounds like you have, you should have proper fuses/breakers at least.
Unread 11-11-2016, 02:00 PM
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
What CNC did you use? For the abused tooth profile of Vex gears (assuming you used those), no C-C add should still work fine, unless you hold poor tolerances. Use a caliper to measure the distance between centers to check the exact distances and see if that's really your problem.
Is there excess friction?
Unread 11-11-2016, 02:25 PM
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #0703 (Phoenix)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
It's worth noting that if you are using Vex gears, running them to wear them down might not be advisable as you would be wearing down the protective ceramic coating and possibly exposing the 7075 aluminum (which is more brittle when exposed compared to standard 6061). The ceramic coating would likely also take longer to wear down than a standard aluminum gear using this process.
If time and cost aren't an issue, I would recommend either using AndyMark gears if you aren't already or remaking the gearbox plates with the 0.002" - 0.003" extra center distance between the gears as others have already suggested (we have always just added the center distance and it works great for us, hardly any noise).
Unread 11-11-2016, 03:07 PM
Type's Avatar
Type Type is online now
FRC #3452 (GreengineerZ)
Rookie Year: 2016
Type is an unknown quantity at this point
We tried the exact same thing too, it's weird that it worked. It may have been the mounting method with the TB mini, but it's worth a try on any gearbox.
3452- Lead Builder/ Pit Boss & Ambassador
*My posts do not reflect the opinion of my team*
