Custom Gearbox is very loud
So we just build our first ever custom gearbox, and it's one of the "opened" once. As in, you can see the gears and all, and when testing it we feel like it's very very loud compared to anything wev'e had before.
Now, all our previous gearboxes were enclosed once, like the ballshifter for example. So what we want to know, if that loud noise is just how it is supposed to sound like with an opened gearbox, or is that means that something's wrong. Thanks! |
Re: Custom Gearbox is very loud
Part of the reason it is louder is because of the exposed gears, but I'm guessing it's not the whole reason. Have you put any kind of lubrication or grease on the gears? That usually helps. Also make sure your gears are not binding up, if they are meshed too closely together, they tend to bind up/be loud.
No it shouldn't be that loud.
We have built several custom open gearboxes times in the past few years - One time it was being put together - it seemed a little hard but the students persevered - and then it screamed when first run! - well it was put together with 14 tooth pinions where the gear centers were set up for 12 tooth pinions - once fixed - it purred. We also find that if using 2 parallel plates with spacers for the gearbox that before you tighten the bolts through the spacers, feel how the gears turn, get them right before socking it down. Ideally we want to control the center distances by a couple thousandths or so - but there is typically more slop in the bolting up process - things you can get away with in FIRST. If it is too loud - screeching - then I would guess the center distance between the gears you are using is too tight, If too loose, it will not be as loud - just lots of backlash, and premature wear. |
If you have a tacometer, measure output speed vs theoretical output speed. This can help estimate how much drag you have. If you are at 75% or lower free speed, you definitely have something too tight. If the gearbox turns very free, and free speed is high say 97% then you may have gear centers too far apart. There will also be a lot of lash compared to other gear boxes.
We are using the 12 pinion once, and we did grease the whole thing.
The plates were made in our CNC machine, and the CAD was done according to pitch diameters of each gear. The loud noise seems to come from the gear that attaches to the CIM pinions (2 motors go to one VEX 72 teeth gear). We would like to avoid fabricating the whole thing again, any suggestions? How much should we separate the gears beyond the tangent distances of the 2 gears? |
Edit: this happened to us twice with different gearboxes and plates in different years. I can't prove it was the same CIM in both cases, but I wouldn't be a bit surprised if they were. Last edited by GeeTwo : 11-11-2016 at 09:51. |
#7
For drive in FRC applications (short runtime, friction bad), it's conventional wisdom to add about .003" to soak up manufacturing variations and go a little loose and free. |
#8
We will try checking each motor separately on Sunday, and than if that doesnt work we'll probably remake the plates. I'll keep the results posted here. Thanks everyone! |
#9
The .003 center adder trick is a way around doing this, at the cost of a bit more backlash in your system. |
#10
Thanks! |
#11
The wear is to some extent controlled by the system not being under load. This would be on a bench, with maybe a wheel or something on the output shaft just for a smidge more inertia. |
#12
What CNC did you use? For the abused tooth profile of Vex gears (assuming you used those), no C-C add should still work fine, unless you hold poor tolerances. Use a caliper to measure the distance between centers to check the exact distances and see if that's really your problem.
Is there excess friction? |
#14
It's worth noting that if you are using Vex gears, running them to wear them down might not be advisable as you would be wearing down the protective ceramic coating and possibly exposing the 7075 aluminum (which is more brittle when exposed compared to standard 6061). The ceramic coating would likely also take longer to wear down than a standard aluminum gear using this process.
If time and cost aren't an issue, I would recommend either using AndyMark gears if you aren't already or remaking the gearbox plates with the 0.002" - 0.003" extra center distance between the gears as others have already suggested (we have always just added the center distance and it works great for us, hardly any noise). |
#15
