Go to Post I think that one of the most fantastic parts about FIRST is that the biggest and most successful teams are also the most abiding to the rules. - Matt Adams [more]
Unread 11-11-2016, 09:00 AM
pnitin pnitin is offline
pnitin is infamous around these partspnitin is infamous around these parts
Re: CANLight - A CAN based LED strip controller
EDIT: Star topology is not recommended, discussed here, and here
I think Long Can network wires can be problem but you have to understand what is "Long". CAN spec says 40 meters, does typical FRC robot have even 8 meter of CAN wire length?
CAN is differential signal so as long as you have twisted pair and proper termination resistor you are good for FRC use. if your network is in manufacturing shop floor then you are in totally different situation
