Go to Post Rules arent built around robots. Robots are built around the rules. - dodar [more]
Unread 11-11-2016, 09:23
asid61's Avatar
asid61 asid61 is online now
AKA: Anand Rajamani
FRC #0115 (MVRT)
pic: GBX-150, CIM-mounted swerve
Unread 11-11-2016, 09:31
marshall's Avatar
marshall marshall is online now
FRC #0900 (The Zebracorns)
Re: pic: GBX-150, CIM-mounted swerve
I'd switch the turning encoder out for one of the versa planetary integrated ones but other than that, this looks cool. Good work!
Unread 11-11-2016, 09:32
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Independent of the swerve aspect, the idea of mounting a wheel based only on the two 10-32 mounts on the face of the CIM is a bit scary. Mounting that arm with a 6-32 and putting a swerve mechanism between there and the wheel have a bunch of alarms going in the back of my neck.
I've seen plans for a VP-compatible cycloid drive, but I don't recall that it's been built, much less made a COTS item. Did you include that in your machining requirements? Is there any advantage of the cycloid drive (vs planetary) in this application other than the obvious weight/space savings?
Unread 11-11-2016, 09:58
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
The main forces on the CIM are thrust loads against the face rather than shear forces, and she shear forces are limited by wheel friction. I'm more worried about the attachment arm. Looking back, I think I can redo the design to use no friction locking at all and use traditional plates, so I might try that next.
VP cycloid should be included in the machining bill, you're right. I like the height savings it provides, mainly.
Unread 11-11-2016, 10:46
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
The thrust load isn't the concern, especially as it's compression. However, if the CoF of the wheel on carpet is greater than one*, the shear forces are potentially greater than the thrust load. What really concerns me are shock loads.
* Except for Lunacy swerves, this seems to be the rule rather than an exception.
Unread 11-11-2016, 12:21
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
Looks very cool. I'm glad to see you are still iterating on your swerve designs.
What I can't gather from this picture is how the primary bearing setup would work. Could we get a cross section view, or an explanation for that?
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 11-11-2016, 13:51
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
That's a good point; I hadn't thought of it that way. Looking back on it, the whole clamping mechanism is a cool gimmick, but not something I actually need... I could also reduce the weight somewhat with other constructions I think.
Thank you!
The bearing setup is definitely an oddball one. Here's a link to the 2015 Offseason folder with the CAD, if that helps:
https://workbench.grabcad.com/workbe...1Z2b-tQWAq3gUh
Essentially, a plate is screwed into the CIM and firmly attaches to the inner race of the 6711 bearing. The outer race of the bearing is pressed into the 64t turning gear and captured with the flanged buttonhead screws seen in the picture.
Unread 11-11-2016, 15:21
Aren_Hill's Avatar
Build Nifty Things
I like the concept, as someone who has utilized the large steel sleeve of the CIM structurally before.
I will warn against taking any loads with the face of the CIM, this is a rather thin wall cast component, which I have seen break in normal mounting configurations.
See if you can find a way to clamp higher up on just the steel sleeve, for both parts, the module rotation and the main frame mount. It'll be interesting to accomplish that and still properly pilot the CIM for the gear mesh.
Also I have next to zero confidence in that wheel/tread setup surviving for a match, once you get past a certain point there is simply not enough contact to transfer the forces required without extreme wear, one of the reasons I stopped at the ~3" diameter territory with my designs.
A guy who likes robots.
Unread 11-11-2016, 15:53
Mechvet Mechvet is offline
Certified Public Menace
FRC #0114
Mechvet is a jewel in the roughMechvet is a jewel in the roughMechvet is a jewel in the rough
R30 (as of 2016) allows modifying a motor housing for the purposes of mounting, which certainly opens the door for structural mounting of a CIM.
It may be possible to entirely replace the output shaft plate of the CIM with your main anchoring plate. Only restrictions I'm seeing from the rulebook would be ensuring that your design is not lighter than the original, and that the electrical and mechanical operation of the motor have not been modified.
Unread 11-11-2016, 16:00
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Originally Posted by Aren_Hill View Post
I like the concept, as someone who has utilized the large steel sleeve of the CIM structurally before. ...
+1
That CIM sleeve is a beefcake. See linked cartoon-CAD of our 2016 winch. (We ended up using an igus bearing, not the PTFE called out in the cartoon. Metric 64mm i.d. fits nicely over the CIM sleeve paint. See picture of the innards also.)
My theory as a motor designer: if you have more than the minimum steel required for magnetic flux, the excess should perform another useful function to justify its weight, cost, claimed space, etc.
Richard Wallace
since 2003
Unread 11-11-2016, 16:05
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is online now
Originally Posted by Richard Wallace View Post
+1
That CIM sleeve is a beefcake. See linked cartoon-CAD of our 2016 winch. (We ended up using an igus bearing, not the PTFE called out in the cartoon. Metric 64mm i.d. fits nicely over the CIM sleeve paint.)
Ok, so does anyone have a spec for the wall thickness for a CIM? Mini CIM? Bag CIM? I'd love to see more and more designs delving into this somewhat uncharted territory of using the CIM body as a mounting point.
Unread 11-11-2016, 16:07
Aren_Hill's Avatar
Build Nifty Things
I think last time I measured it was ~0.090" thick, it's not going anywhere.
Unread 11-11-2016, 16:08
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Thanks for the advice. I thought the face was machined, but if it breaks that easily it looks like I'll have to rethink a lot of it. I'm currently working on an iteration of this idea that should be stronger while pushing the weight under 5lbs (finally).
Does the tread just come off such small wheels, or is there another problem? I was thinking of just using a colson if what you're saying is the case.
I recall seeing old threads about a team machining the paint off the CIM to make it shiny, but I want to avoid machining more COTS components than absolutely necessary. That being said, replacing the front plate of the CIM would be an elegant solution.
Unread 11-11-2016, 16:09
Ok, thanks. I've only opened a CIM once, and I wasn't paying attention to the sleeve as much as the internals.
Unread 11-11-2016, 16:16
Aren_Hill's Avatar
Build Nifty Things
A colson would work better as the bond to the polyolefin core is very strong, but it would still wear out faster than you'd think.
Replacing the ends of motors has been on my "i'd like to do this..." list, but I never have as I'd likely lose the rules argument, you are getting a weight/performance advantage when you integrate the motor into the structure like that. And I read "modified to facilitate mounting" as "mess with it some if need be, but don't replace it".
I had a concept once that would replace the dead axle of a window motor with a powered shaft through to get an on-axis steering motor, but never made it past that as I'm pretty sure I'd lose the legality argument.
-Aren
