Go to Post Don't let your FIRST blinders prevent you from thinking. - JaneYoung [more]
Unread 11-11-2016, 16:16
Aren_Hill's Avatar
Build Nifty Things
Re: pic: GBX-150, CIM-mounted swerve
Originally Posted by asid61 View Post
Thanks for the advice. I thought the face was machined, but if it breaks that easily it looks like I'll have to rethink a lot of it. I'm currently working on an iteration of this idea that should be stronger while pushing the weight under 5lbs (finally).
Does the tread just come off such small wheels, or is there another problem? I was thinking of just using a colson if what you're saying is the case.
I recall seeing old threads about a team machining the paint off the CIM to make it shiny, but I want to avoid machining more COTS components than absolutely necessary. That being said, replacing the front plate of the CIM would be an elegant solution.
A colson would work better as the bond to the polyolefin core is very strong, but it would still wear out faster than you'd think.
Replacing the ends of motors has been on my "i'd like to do this..." list, but I never have as I'd likely lose the rules argument, you are getting a weight/performance advantage when you integrate the motor into the structure like that. And I read "modified to facilitate mounting" as "mess with it some if need be, but don't replace it".
I had a concept once that would replace the dead axle of a window motor with a powered shaft through to get an on-axis steering motor, but never made it past that as I'm pretty sure I'd lose the legality argument.
-Aren
A guy who likes robots.
