Go to Post Mr.Lavery You Make My Day - Rohith Surampudi [more]
Unread 12-11-2016, 22:51
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Keeping #35 Chain Tight
Originally Posted by Knufire View Post
My suggestion would be to calculate the exact center-to-center distance, then add 0.012".
If you do sliding blocks, (I wouldn't be too worried about the drivetrain drifting to one side as long as everything is properly tensioned), I'd use the small cams from WCP so you're not entirely relying on the friction between the block and tube to hold the block in place.
Agreed. #35 is very toleranct on spacing, so even if it wears a little you will almost never throw a chain. I don't think I've seen a #35 chain fail before, although I'm sure others have seen it.
