Re: ShopBot Desktop router up for the challenge?
I just purchased an X8 (w/ x6 usb controller) from Omio CNC that came with the same spindle, and happy with it so far. |
Is there anything aside from those specs that I should keep an eye out for? Good/bad manufacturers? |
Woah, an inexpensive (relatively compared to the other options they sell) Haas machine aimed at education? We'll be taking a good look at this one. Also, if anyone else is encountering a 404 when they try to visit the Haas page, I found a data sheet for it: http://haascnc.com/DOCLIB/Datasheets/DS_MM-EDU_US.pdf |
FWIW this isn't as screaming a deal as I first thought. If you spec this out as a standard minimill is configured you basically end up at a slightly better price than the educational discount Haas offers for a purchase of any machine, with a worse warranty (educational purchases come with a 2 yr warranty, this one you have to pay for a 1 year warranty). The kicker may be the extras they include as part of the classroom kit. It doesn't specify what those are, but if they're including CAD/CAM and tooling certificates that could well push it over the top. That being said, if you don't need all the things that come standard on the non-educational minimill this would be a great way to get into an entry level machine that is going to be worlds better than any hobbyist grade machine (including tormach). |
#7
What makes the Haas Mini Mill EDU cheaper than the standard Mini Mill is that it does not come with a tool changer, which may or may not be a big deal for you. For me, I would go crazy having to manually change tools, but with a CAT40 spindle it's not as bad as some other systems. And as Cory mentioned, the Haas is easily twice the machine the Tormach is, any day of the week. When we first started into CNC machining, we almost pulled the trigger on a Tormach 1100 fully optioned out, but if I recall, the price was up around $22k with tooling and whatnot. We were able to push tooling to a separate budget, up the machine budget a little bit and go for the Haas, and it's been one of the smartest things we ever did. I filled a 55 gallon drum with chips machined in it it just today. Try that on a Tormach. As for router spindles, anything less than 2HP is not going to give you any respectable cutting power. We've had a Porter Cable 2 1/4 HP and a Hitachi MV12 2 1/4 HP. The Porter Cable was deafeningly loud. The Hitachi is substantially quieter, but is smaller in physical size, and lacks the torque that the Porter Cable had. I can imagine cutting with a 1HP spindle to be akin to watching paint dry. |
#8
Our situation is such that right now we will probably only make one or two custom gearboxes in a season and are willing to spend the time. In the future we could upgrade to a big beefy spindle and improve that time. |
#9
Dave and Cory,
Thank you so much for posting your thoughts on the Haas machine! We were looking towards a Tormach, but this new option will probably be high up on our machinery purchase list this season. Also, I'm really intrigued about the included curriculum etc. listed on the data sheet so I put a request for more info in. I will update everyone if/when I get literature and material from Haas. Thanks again! Last edited by frcguy : 14-11-2016 at 13:54. |
