Re: ShopBot Desktop router up for the challenge?
I suggest you find a way to make room for a machine that will do what you need. Specifically, having the ability to cut your own rails. So I suggest an X or Y axis of at least 36 inches, so that you can do an entire rail without repositioning the piece.
I like our Velox, so in your position I would seriously look at the VR2536 with a 3 HP HSD spindle. http://imgur.com/a/sXwSB At least look at the http://shopbottools.com/mProducts/desktop-max.htm but I would be leary of the 1 HP spindel. A spindle is significantly quieter than a router on these type of machines and gives you a way of controlling your tool speed(RPMs). You will need to mount some type of coolant system compressed air and/or a mist system. You can't be recutting the same chips over and over, so compressed air to clear the chips is a must. These single flute tools from tools today do a great job on aluminum and clear chips pretty well. http://www.toolstoday.com/p-5801-sol...uter-bits.aspx You can build your own enclosure and/or get a vacuum hood. https://www.youtube.com/watch?v=rrKKsYCb8Tg I suggest you get something you can grow into, once you start your own machining I doubt you will want to do less. Last edited by Fusion_Clint : 13-11-2016 at 21:44. |
Please find your selves more room to put a bigger machine in, the cost is marginal and the utility is HUGE. Please don't limit yourselves to 24", I know it's a lot of room but it is such a valuable machine. We machined at least 75% of all 3 robots we built last season with our VeloxCNC 50x50, you will use all the space you buy. You could potentially mount it to a wall and not the floor to make the foot print smaller, Velox should be able to handle it without noticing. Just be clever and I'm sure you can come up with a solution, we build robots after all. |
Other than that, this is a fairly common configuration with lighter duty machines. |
We have both a ShopBot Buddy 2'x4' router and a Tormach 1100. Both are fantastic tools. If I had to choose one, though, I'd choose the router without a second thought for FRC. With that tool with a 2'x4' build volume you can fabricate an entire FRC robot. Sure, there are 3D things you'd have a hard time doing without the CNC mill but you just design your robot for the tools you have. Being down the road from ShopBot sure doesn't hurt either. Check out the 2016 reveal video of Zuko which was build entirely using the ShopBot buddy, no other CNC tools and no outsourcing.
Do you have a gauge for the level of noise produced by this machine? |
Same as you, when the chopsaw whirs, I stop mid-sentence to let it finish. I can now talk over the gantry mill.
For ours, with a 3kW water cooled spindle...The spindle on at cutting speed is just a hum, very quiet. We have a 2HP blower in the room that is a bit louder. You do get some noise when cutting, especially if you have a poor cut or any chatter/vibrating, but that should be addressed for other reasons than just noise. When we had a commercial router (air cooled), you had to yell to talk over the gantry. While i wouldn't characterize the new spindle it as "quiet" at least it is fairly consistent so you just adjust your voice over it. Additionally, normal routers force air down towards the bit for cooling, which blows dust everywhere. A water cooled spindle is a lot better for that natively, but you may still want air assist and a vacuum for chip management. tl:dr;, Our setup isn't quiet by any means, but it isn't deafening, and we can work in the area while the mill is running without difficulty communicating. |
#7
If you got the water cooled 220V spindle, they are WAY quieter. I will gladly help you find a source from China for a spindle if you desire as they are WAY cheaper(even if you need a VFD to get the voltage). I want to change out our router for a spindle because it is much nicer to work with because you can control your speed via code. My offer goes for everyone by the way, machines are one of the biggest things I do on 1678 and I love talking about it and helping others with what I know. |
#8
http://www.ebay.com/bhp/cnc-spindle-motor
or https://www.amazon.com/s/ref=nb_sb_s...=2LEHNTN7VNJII I would suggest a 2.2 kw water cooled one with ER20 collets. If you do not have 220V power you will likely require a VFD as well. You will also need to make sure that you will have a mount to hold it. Last edited by RoboChair : 15-11-2016 at 15:22. |
#10
I just purchased an X8 (w/ x6 usb controller) from Omio CNC that came with the same spindle, and happy with it so far. |
#11
Is there anything aside from those specs that I should keep an eye out for? Good/bad manufacturers? |
#12
http://www.automationtechnologiesinc...d-110vac-input http://www.automationtechnologiesinc...illing-spindle |
#15
We bought the 3 HP HSD Spindle with VFD when we got our VR 50 X 50 Velox.
We also have an older K2CNC 24 X 36 inch with the 2.25 porter cable router. We can hold conversations with either machine running, neither are close to a chop saw. The router on the K2 sounds like a wood router, loud but not horrible. We try to keep the aluminum jobs for the Velox. The HSD spindle on the Velox is just a light hum, at least 90% of the noise is from the actual cutting of the materiel. When doing air cuts to ensure proper tool paths, the stepper motors make it sound just like our 3D printers. One perk of getting it all from the manufacture is the awesome customer support, last year on Day 1 of Build Season a student spilled the contents of our coolant container on our control box for the Velox (completely our fault and we told them so). Velox shipped us a replacement control box at no cost, we just covered the overnight shipping and we were back up on running with minimal time lost. Great Folks at Velox! |
