Go to Post Why is it whenever you tell someone there is a million billion stars in the universe they believe you, but if you tell someone that the bench over yonder has wet paint, or if usfirst.org comes up as the 1st result in Google people have to try it for themselves? - artdutra04 [more]
Go Back   Chief Delphi > Technical > CAD
Unread 14-11-2016, 10:13
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
Inventor Help
Whenever I try to put AM wheel files into an assembly, the computer freaks out and tells me this cannot be done. Does anyone know a way to get these files into an assembly?
It isn't shiny enough.
Unread 14-11-2016, 12:05
Zealii's Avatar
Zealii Zealii is offline
#QuadSquad
FRC #3494 (The Quadrangles)
Team Role: Student
Zealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond repute
I would recommend opening the .stp wheel file in a new window so you can save it as the inventor file format first. Then you can place the .ipt into your assembly file. Hope this helps!
2014-Queen City Regional Finalists (868 & 3506)
2015-IndianaFIRST Kokomo District Finalists (5402 & 4982)
Unread 14-11-2016, 12:25
Re: Inventor Help
Would there be any other problems that could occur with the wheels being their own assemblies?
Unread 14-11-2016, 12:48
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
Re: Inventor Help
No. You can use assemblies within assemblies. The AM wheels would then be considered a sub-assembly of the assembly you placed them in.
It sounds like the file type is the issue. Inventor (and many other CAD packages) does not handle STEP (.step .stp) ile conversion at the inserting into assembly level. Our rule is to always open and convert the STEP file to a native CAD format, save, and use the newly created file.
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Zealii's Avatar
#QuadSquad
Team Role: Student
Not that I can think of. Placing assemblies in other assemblies has never given me any issues. It just creates nested assemblies.
Unread 14-11-2016, 13:11
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
Re: Inventor Help
It sounds like you are trying to place a .step file directly into an assembly. You have to import the .step file first, save it as a .ipt part or .iam assembly. And then place that part/assembly into your current assembly.
Team 3991: Driver since freshman (2015-), Captain since sophomore (2016-), CADer
"The human condition is not perfect. We are not perfect specimens, any of us. We're not robots." - Michael Ovitz
My posts may or may not reflect the views of my team, they are my opinions, and mine alone.
