Re: Getting Started with Sprockets and Chain
This past season my team had a shooter arm rotate about a shaft powered by a chain and sprocket. The first step in a successful design is selecting the correct motor and reduction. The RS775 is a great motor but it doesn't do the best when stalled as its fan needs to be spinning for it to stay cool. You can check out the amazing resources at Vex Pro (http://motors.vex.com/) to see the very elaborate motor testing they have performed. Towards the bottom of this page (http://motors.vex.com/bb-775) you can see the locked rotor stall test. The graph shows that over just 20-30 seconds a stalled 775 will burn out and provide no torque. Taking that into consideration, I would recommend a bag motor (http://www.vexrobotics.com/217-3351.html) Although it has a lot less power, it is okay with being stalled for a little longer (http://motors.vex.com/bag-motor)
That being said, there are some amazing resources out there to help you design a chain driven arm. The first and a tool I use very often is JVN's design calculator. Don't forget you can get a reduction in your gearbox and in the sprocket. https://www.chiefdelphi.com/media/papers/3188 Using this very simple spreadsheet you can mess around with different motors and reductions until you get the speed and power draw you are looking for. I suggest you use the "Rotary Mechanism" tab for your current project. As for what gearbox to use, there are quite a few choices but my team and many others have successfully used vex pro VersaPlanetary gearboxes (http://www.vexrobotics.com/vexpro/mo...planetary.html) they are very flexible and can be used in many different gear ratios. Finally, once you have your reduction picked out you will need to calculate the spacing between the two sprockets. This site (http://www.botlanta.org/converters/d.../sprocket.html) has worked well for us. I would use your mill with a DRO to machine a perfect center to center between the sprockets. If you choose not to do this, you can always use a chain tensioner of some sorts, there are many different designs out there. |
Since you're powering an arm, I'd check out this thread about passive assistance.
https://www.chiefdelphi.com/forums/s...&highlight=jvn There's some good advice in there on how to reduce the amount of power you need running through your system, which is always a good thing to consider. |
#25 chain is plenty strong for moat any FRC application, but due to the relatively small tooth size on the sprockets, the chain tension is very important. It weighs less than #25. Also due to the smaller tooth size, you can get more teeth on a sprocket of a given diameter.
#35 chain is considerably more forgiving on chain tension, but it weighs more than #25. It is also a bit easier to work with since things are not as small. It is stronger, but you generally do not need such strength. Why are tooth counts on a sprocket important? The ratio of speed for sprockets goes by tooth count. For example, a 15 tooth sprocket turning a 30 tooth sprocket (via chain...) has a 2:1 ratio of shaft speeds. A 72-tooth sprocket is fairly large in #35, more reasonable in #25. McMaster.com can show you the range of sprocket sizes available. |
some real world advice...
use the chain that is easiest available... look to industry around you for parts... 35 is easy to find parts and links in hardware stores... look to old farm machines for great examples of ho to convvert speed to force and back again.. look at specs for a square baler or corn picker... both are driven off 1 or at most 2 power sources (the PTO)& (second can be the wheel) all the moving parts are driven from that one source... BEWARE of Fingers... |
If you are looking to learn the chain basics we (REV Robotics) released a chain guide with our products for FTC this season. Since we use #25 chain in those robots also the information is directly applicable to FRC as well.
http://www.revrobotics.com/content/d...cket-Guide.pdf |
#7
What I would recommend is to use parts from a standard FRC supplier (VexPro has a huge supply of sprockets and chain to choose from), even if sometimes they may be slightly more expensive. With FRC suppliers you know the quality of the product, they have amazing customer service and fast shipping, and the parts are standard so it greatly increases the likelihood of bring able to find a replacement when you badly need one. This isn't to say that industry parts won't work (god knows I've stuck a few of them on robots in the past) just that in most cases there are better options. Last edited by Ari423 : 15-11-2016 at 01:55. |
#8
to clarify.... I did not say use machinery parts.. I stated look at examples of how it works.. often we can stan on the knowlege of others and not recreate the wheel... for that matter look at a 21 speed bike.. same concepts of how to set up gears... to get the most movement or power depending onthe need...
then go and find approved parts to do the job... good luck... READ BEFORE your comment... not SKIM... |
#9
It's not just stalling a motor that kills it; heat kills it, which is proportional to current. A 775pro stalled at 4v is the same as stalling a BAG at 12v in that regard. You can "stall" a CIM at 0.5v, but it's not going to kill the motor any time soon. To the OP: 775pro > RS-775 for a variety of reasons, but you can make any motor work. If you want to save money you might be able to dig up a CIM (many teams have them in excess). 180:1 may not be high enough if you want to control it accurately. As a rule of thumb, I like to make sure I'm only running at 5-6% of a motor's stall current (or about 7 amps for a 775pro) to make something very easy to control. JVN Calculator 2016 makes these calculations a breeze. Then you can use a simple PID controller to control your position. This is very conservative, but for teams just starting out with encoders and controlling things accurately I like it. For a low load like yours on an 18" arm, I'm getting a number around 600:1 for a speed of 0.5rps to maintain 5-6% stall current, but JVN calculator will help you narrow down your options. Last edited by asid61 : 15-11-2016 at 03:08. |
