Go to Post I think this is the forest that ChiefDelphi often misses as we're picking the branches off every tree. - Libby K [more]
Unread 11-14-2016, 07:11 PM
snoman's Avatar
snoman snoman is offline
FRC #3275 (Accelerators 3134 & Regulators 3275)
snoman is a glorious beacon of lightsnoman is a glorious beacon of lightsnoman is a glorious beacon of lightsnoman is a glorious beacon of lightsnoman is a glorious beacon of light
Toughbox Mini
Looking for a stl file of the housing. thanks
Coach of the Cass Lake Bena Regulators 3275 (Boys)and mentor Accelerators 3134(Girls)
https://www.facebook.com/accerleratorsandregulators/
https://www.youtube.com/channel/UCQU...Cr8I4wezAbMefA
Unread 11-14-2016, 09:31 PM
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: Toughbox Mini
Here's a stp file for the whole gearbox: https://www.dropbox.com/s/kx8v65ba3q...-mini.stp?dl=0
I didn't realize that these things vanished off of andymark's site. (You guys should keep these older files up somewhere if you can! Useful info for people who buy your products)
Unread 11-14-2016, 09:33 PM
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Re: Toughbox Mini
After having difficulty finding the step file of the individual gearbox on the Andymark website. I downloaded the 2016 KOP chassis model and used that to obtain the model of the gearbox housing.
If you a wanting to 3D print it ( which I am assuming as you asked for an stl file), you might need to do a few modifications to the model to make it more suitable for printing. I rotated the housing so that the area of the housing where the CIMs are connected will be on the print bed but you may still need to modify it depending on how good your printer is at doing support material. I have uploaded the .stl, .step and the solidworks part file to enable you to do this.
https://grabcad.com/library/tb-housing-1
If you need help modifying it just send me a PM or reply below.
The .stl file may be 25.4 times larger then it should be because being an Australian, my SW is set in mm not inches so be careful.
Facebook
Unread 11-14-2016, 09:48 PM
troy_dietz's Avatar
troy_dietz troy_dietz is offline
3D printing and Alliance Captain
FRC #0330 (The Beach Bots)
Team Role: Human Player
Rookie Year: 2015
troy_dietz is on a distinguished road
Re: Toughbox Mini
The default unit in most slicers is mm. Exporting in inches is more likely to create a scaling issue.
Edit: Just checked, the scale on the .stl is correct.
