Go to Post IRI: it's FIRSTmas in July! - Alan Anderson [more]
Unread 15-11-2016, 11:39
Wren Hensgen's Avatar
Wren Hensgen Wren Hensgen is offline
Alum, Mentor, Volunteer
AKA: Wren Hensgen
FTC #10353 (MetalWorks)
Wren Hensgen is a jewel in the roughWren Hensgen is a jewel in the roughWren Hensgen is a jewel in the rough
Re: What brand of pneumatics do you use?
We used mainly Bimba for cylinders, because they're more readily available (produced stateside), and offer more customization options. You can configure a cylinder on their site, and have a CAD model ready to test instantly.
We used to use FESTO, but have swapped over to Humphrey for solenoids, as their balanced series switch faster, and have better flow in a smaller package.
For fittings, we had a mix of SMC/Parker, which were swapped over to Norgren (Norgren has the inside of the fitting hex broached, so you can tighten them with an allen wrench, a lifesaver in tight spaces)
Through FRC, I now work for a fluidics (Hydraulic and pneumatic) distributor. If you have any questions, or are looking for a certain part, I'd be happy to help
