Go to Post I walk through the door, and suddenly the field breaks down. It must be my magnetic personality. - Swan217 [more]
Unread 15-11-2016, 15:52
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Re: ShopBot Desktop router up for the challenge?
Originally Posted by RoboChair View Post
http://www.ebay.com/bhp/cnc-spindle-motor
or
https://www.amazon.com/s/ref=nb_sb_s...=2LEHNTN7VNJII
I would suggest a 2.2 kw water cooled one with ER20 collets. If you do not have 220V power you will likely require a VFD as well.
You will also need to make sure that you will have a mount to hold it.
I'm 90% sure you need a VFD to use these spindles in any setup. I've used a couple on different machines and they all have parameters that must be set in the VFD to avoid damaging the spindle from over speed. I don't have much knowledge of AC power systems but I'm fairly sure that if they were hooked up directly to 3 phase power It wouldn't work or spin far too slow for machining. Likewise I've never seen someone hook one up without a VFD.
2016: FRC 865 Mentor
