Go to Post I remember going to Houston in 1998 and seeing a bot that could move sideways. Talk about inspiring... - Ken Patton [more]
Unread 15-11-2016, 22:58
TheRozb's Avatar
TheRozb TheRozb is offline
Jack of All Trades
AKA: David So
FRC #0955 (CV Robotics)
TheRozb is an unknown quantity at this point
Polycord Pulleys
Hey Everyone,
Where do you source your polycord pulleys? We need some that will go onto 1/2 inch hexshaft. Do you just make your own in house? I've done some Google searches but not much luck...
Thanks
Unread 15-11-2016, 23:09
TheIsaacMurrin TheIsaacMurrin is offline
FRC #4269
TheIsaacMurrin is an unknown quantity at this point
Re: Polycord Pulleys
https://www.mcmaster.com/#round-belts/=1524smf
Unread 15-11-2016, 23:13
TheRozb's Avatar
Jack of All Trades
AKA: David So
Not the polycord itself, but what it sits on.
Thanks
Unread 15-11-2016, 23:14
Billfred's Avatar
Billfred Billfred is offline
Originally Posted by TheRozb View Post
Hey Everyone,
Thanks
2815 used polycord in 2009 and 2012. Both times, we used some ABS or Delrin rod from McMaster, cut the necessary grooves on a lathe, then broached it for 1/2" hex.
Unread 15-11-2016, 23:19
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
We used a lathe to throw some grooves onto these. http://www.andymark.com/product-p/am-1305.htm
Nowadays I'd just 3d print them
2016: FRC 865 Mentor
Unread 15-11-2016, 23:20
TheRozb's Avatar
Jack of All Trades
AKA: David So
PLA? ABS? Is it strong enough to handle the force?
Unread 15-11-2016, 23:21
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Are the "necessary grooves" just a semicircle of the correct diameter, or is there more of a trick to it?
Unread 15-11-2016, 23:25
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
If you have access to a 3D Printer you could design and print them.
In 2016 we used PLA Pulleys (with a 10-15% infill) and there were practically indestructible. Through the entire season we only broke one. The one we did break was destroyed by smashing it with a hammer.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 15-11-2016, 23:37
Billfred's Avatar
As I remember it, we went a little deeper in to ensure enough contact between the drive axle and the cord--but that might be just voodoo for us. You can always wrap a little wedgetop or roughtop around the outside for extra grabbing, if necessary.
I'd definitely keep the width at or below the width of the belt itself, to keep them from walking or having more room to deform and let something by.
Unread 15-11-2016, 23:58
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
We've made a lot of these. It needs to be a deep channel - polycord is sticky and likes walking out if you put any side load on it.
However, consider using flat polycord belting. Round polycord slips even when it's very tight. Flat belting doesn't. And with the belting, you can just build up a high spot on the roller using anything you like - tape, rubber o-rings, etc. and the belt will keep itself straight.
Disclaimer: belt can be much harder to weld than cord.
Mcmaster sells round belt pulleys.
https://www.mcmaster.com/#round-belt-pulleys/=1525gp9
Unread 16-11-2016, 00:51
Max Boord Max Boord is offline
FRC #0179 (The Children of The Swamp), FRC #1592 (Bionic Tigers)
Team Role: Tactician
Max Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant future
3d printed pulleys work well depending on infill and load. 179 used them to transfer load between the middle to front and back rollers and had to wrap them in duck tape to get enough friction to transfer the load effectively. on 4592 we ran 2 775pros on our intake with quite a bit of compression and found a need to replace a pulley or 2 every match due to cracking however this should not be an issue in most situations as most of ours where broken by hitting other robots and the middle CDF plank. The best solution we found was to run loads of them (i think we ran 7 to 11 depending on the revision of the intake) and be ok with running with a few missing/ broken.
1523 (2011-2014)
1065 (2014-2016)
3932 & 4592 (2016)
Unread 16-11-2016, 01:14
AlexanderLuke's Avatar
AlexanderLuke AlexanderLuke is offline
Do More. Less Time.
FRC #0696 (The Circuit Breakers)
AlexanderLuke is a splendid one to beholdAlexanderLuke is a splendid one to beholdAlexanderLuke is a splendid one to beholdAlexanderLuke is a splendid one to beholdAlexanderLuke is a splendid one to beholdAlexanderLuke is a splendid one to beholdAlexanderLuke is a splendid one to behold
We have been 3d printing custom designed pulleys for prototyping with polycord when the time arises. I can attest to the need for making the grooves deep. The belts will run off the pulley or slip off with side loads if the groove is not deep enough.
The information other people have already posted is a great resource for you as well.
2014-Present ~ Team 696: The Circuit Breakers - Student Leader and President, Drive Coach, Mechanical Designer
Unread 16-11-2016, 02:19
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Back in 2012 when my team used polycord belting, we just lathed up some delrin and it worked fine.
I would imagine 3D printing would work just as well if you can; the pullies aren't going to be under particularly high stress.
Haven't seen it mentioned yet, but be aware that over the season, the polycord will stretch and you'll have to have some extra made for replacement. Or have a system to de-tension them between matches to help the lifespan.
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 16-11-2016, 07:08
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
One very successful method is sandwiching a banebots wheel between two polycarb discs. I know 1741 used it for their intake this year.
It isn't shiny enough.
Unread 16-11-2016, 07:40
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
Team 423 used VexPro 3.25" VersaWheels one next to each other as an intake last year. The gap between the treaded parts of the wheels is .370" which is the perfect size to hold in 3/8" poly cord (I think it was 3/8 but it may have been one size smaller). They occasionally would walk into the next groove over if they got a lot of side force but for the most part they worked like a charm. On the other end, we used a piece of PVC tube with slices of a larger PVC tube screwed into it to create grooves. If you don't have access to a lathe or 3D printer, PVC tubing is very versatile and you can find it in almost any hardware store.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
