Go to Post A true team can only be formed by people who care about each other and that have a common goal... - keehun [more]
Unread 11-16-2016, 02:32 PM
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is offline
I'm not very good at giving prizes
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Poseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to behold
Re: Definitive Guide to Using the Jetson TK1/TX1?
Originally Posted by RyanShoff View Post
I just did this a couple of months ago. Next time we'll try to document it better.
You need a system running Ubuntu 14.04 to install the Jetpack on. A vm might work but I haven't tried it. I did manage to get it work from 16.04, but I would stick to 14.04 if you can.
The current Jetpack documentation is here:http://docs.nvidia.com/jetpack-l4t/i...4t_install.htm
Make sure you install OpenCV for Tegra and CUDA toolkit. You might not want to install some of the samples or machine learning packages.
The install will walk you through putting the board in recovery mode.
Last year we used two builds of our code. One with a GUI to view the processing for calibration and one without the GUI. We would ssh with X forwarding into the TK1 to use the GUI version.
Our code with here: https://github.com/FRC-Team-4143/vision-stronghold
It documents most of the tweaks to the standard configuration we used. I need to clean up a couple of symbolic links in /etc that git didn't follow.
So you do need a system running Ubuntu to use the Jetson?
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
